67 Automatic shifter cable
Old Aug 21, 2018 | 05:42 PM
Keith Jones's Avatar
Has anyone ever had to adjust the shifter cable on a 67 4-4-2 that has an Edelbrock card and intake manifold installed ?
I am having trouble adjusting my shifter cable to function correctly. The only way the start circuit will work is to forceably shove the shifter forward of the parking notch on the shifter. It has a new neutral safety switch and that did not correct the problem. I was told by a seasoned mechanic the the carb linkage is adjusted differently from the Quadrajet to the Edelbrock. Any one else had this issue ?
i
Old Aug 21, 2018 | 06:33 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Keith, more information, you're confusing me/us.
Throttle linkage is seperate from trans shift cable. Do you have a console-shifted automatic or is it on the column? Ill assume you have bucket seats with a console shifter? If so NSS (neutral safety sw) adjustment is on the neutral safety switch on the console shifter. Or are you describing the transmission passing gear kick down? Is this a 2 or 3 speed auto trans?
Old Aug 21, 2018 | 06:35 PM
i
The carb linkage has exactly nothing to do with the shifter cable or the NSS. First, be sure the cable is adjusted properly. There is a slotted hole where the cable attaches to the arm on the trans. Put the trans and shifter in PARK, loosen the nut, and adjust as needed. Tighten the nut. Once you do that, remove the console and adjust the NSS on the shifter.
Old Aug 22, 2018 | 05:04 AM
A dollar and this will buy a coffee, but whoever put carb and intake on probably messed with too many things and threw it out.
Your throttle linkage, in addition to controlling the carb, activates the kick down and the switch pitch converter. Considering that wide open is fairly easy to adjust, there may have been shenanigans with the torque converter pitch adjust and then stuff messed with accordingly. Olds had the switch pitch sit in high at idle (to avoid creep), low in off idle and primary (for responsive low rpm take off), and high throttle was high pitch (to allow spooling up.) It could well be that the new carb made it in low at idle, or high at part throttle, neither of which is awesome.
Old Aug 22, 2018 | 06:18 AM
That is all true, but it still has nothing to do with the shift cable or NSS.
Old Aug 22, 2018 | 05:16 PM
I did not claim it to be such.
Old Aug 22, 2018 | 05:31 PM
The OP was told that somehow the E-brock carb required a different adjustment procedure related to his NSS problem. Your post unintentionally added to that confusion.
melo123
Jun 13, 2018 01:50 PM
nitrovette
Aug 12, 2014 04:15 PM
gearhead1218
Jul 19, 2013 10:41 AM
onofre442
Jan 24, 2013 11:08 AM
weasel
Feb 8, 2011 07:36 PM
