Weird Science
Old Jul 23, 2018 | 10:05 AM
F-85 4-4-2's Avatar
Weird Science
Driving the '66 4-4-2 home on Saturday evening, I turned on the headlights. And the car instantly quit. No electric at all, acted as though it had no battery. Even jumped to a good battery, zero, zip, nada.
45 minutes later, jumper cables long disconnected, with a tow truck confirmed, it decided to come back to life. I fired it up and drove it home without issue. The battery, and continuity in both the positive and negative cables, test A-OK, and no issues driving it around yesterday, with lots of headlight on-offs, with and without brights (brights were "on" when it quit).
Ideas? I was thinking intermittent battery failure, although even with the jumper cables connected, there was still nothing. And, as far as I know, no alien spacecraft hit me with an electromagnetic pulse.
Old Jul 23, 2018 | 10:19 AM
RandyS's Avatar
If it was a battery issue, your car should have kept running from the alternator even with the battery disconnected. I would suspect an issue in the ignition system. Possibly the switch, or the NSS.
Old Jul 23, 2018 | 10:32 AM
frankr442's Avatar
Bad ground connection?
Old Jul 23, 2018 | 10:35 AM
Check the bulkhead connectors on the drivers side firewall and the connection on the horn relay power stud..
Old Jul 23, 2018 | 10:40 AM
stellar's Avatar
stellar
Bad connection at the battery or battery cables. Check both ends. If it has fuse links check them.
Old Jul 23, 2018 | 06:09 PM
F-85 4-4-2's Avatar
NSS?
All is well on the + stud at the horn.
I'll scope the bulkhead next.
Weird that even with the jumper cables on the battery cable ends, nothin'.
Old Jul 23, 2018 | 06:16 PM
RetroRanger's Avatar
72 Olds CS
NSS = neutral safety switch
Old Jul 23, 2018 | 06:30 PM
Originally Posted by F-85 4-4-2
NSS?
Not that weird as the main power goes from the horn relay through the bulkhead connector to a spice and then to ignition switch, fuse box, light switch, etc...
Old Jul 23, 2018 | 06:31 PM
F-85 4-4-2's Avatar
I don't think '66 manual's had a NSS.
Old Jul 23, 2018 | 08:56 PM
RandyS's Avatar
No, it did not, I was thinking he may have an auto tranny.
Old Jul 24, 2018 | 07:10 AM
No manual transmission cars ever had an NSS. They had a CLUTCH START SWITCH that had nothing to do with which gear the trans was in at the time. And yes, Olds did not start using a CSS until the 1969 model year.
76olds
Mar 3, 2014 03:31 AM
TenMidgets
Jan 14, 2013 03:41 PM
FATRATMATT
Jul 9, 2010 08:18 AM
JSGD1966
Aug 27, 2008 07:40 AM
1972madison
Jun 20, 2007 02:01 PM
