View Full Version : General Discussion
- Autonomous cars - question answered
- Real name of piece on a convertible top
- 71 cutlass color
- Our 1969 Cutlass
- Fiberfab Avenger GT40 with 455 OLDS
- Order of install on dash ( 71 Cutlass )
- Jackie Cooper Oldsmobile Yukon, Oklahoma
- 68/69 vintage Lakewood scatter shield???
- What other vehicles would these wheels/tires fit on?
- Attention olds people
- Chris Whitt
- Have a 70-442 4 speed. Cannot get right rear back up to operate
- 1972 Cutlass sport mirror glass
- Yukon Chevrolet Oklahoma?
- Who is making the dipstick tubes?
- 66 Toro.
- Headed to Dallas Friday
- Small block in full size olds
- olds show today phoenix?
- '66 Tri power set-up
- Quadrajet Question
- Neutral safety switch
- Who Has Any Experience with Welding Repairs on Stainless Steel Trim?
- Flathead Head Gasket Keeps Leaking
- Rear deck spoiler
- its back 64 faux faux deux
- Where to buy a Quality Master Cylinder
- Correct wheel trim rings
- Enterprise commercial
- Power steering
- Woman hit by autonomous car!
- 67 442 intake repl. w/aluminum
- First post for me! Hello
- Proper tire size to size of rim
- door mirrors
- Hidden VIN
- Car Cover for a 1955 Oldsmobile
- Alternator restoration recommendation wanted
- Do you see anything wrong with this a/c set-up?
- Help
- 79 Cutlass T Top manual trans on Craigslist today $300.
- Buick to no longer put "Buick" on its cars
- 70 White Paint Stripe: Classic White or Cameo White?
- How many are drag racing with a manual transmission
- Good deal?
- 1970 442 quarter windows
- Head rests
- drum brakes
- Fuel Vapor Cannister Rebuidlable?
- Question about 1968-72 Post car side trim
- 60s-70s cars and their future value
- Is there a way to ID these?
- Old Oldsmobile parts , are these even worth keeping?
- Anyone use the Pypes 2.5" factory tips with a non cut out bumper?
- Headers that fit 71 442 4 speed
- 1970 sport mirrors
- choke tube question
- 1970 possible w30 find. Highly optioned
- Need some help!
- Golf Cart Transport Florida to Michigan
- 350 - JM 20- 22 cam results
- Is the Plastic Sleeve for the Seat Back Locking Pin Available?
- 1970 intake gasket
- 66-67 drip rail moldings
- package tray
- '69 Cutlass S power steering question
- genius
- Interesting read
- Long Island & NYC Olds Club Spring dust off
- Olds 425-powered Go Cart
- Factory GM Rally wheel back spacing
- steering wheel swap
- World of Wheels Chicago
- OPGI Discount Code
- 72 Cutlass AC ducting
- Vintage Air
- Parts for "C" body
- lift supports for 72 cutlass trunk
- 1972 Cutlass Hood Help
- 1964 olds 88 heater,ventilation vacuum hose diagram
- 1965 Cutlass horns
- 80's caliente estate auction
- 60's Delts Mark Ten B Capacitive Discharge Ignition
- Jerry Freeman 95th Birthday
- Possible F heads
- Hubcap locks missing??
- Who produces the best OAI 69 W bumper ducts????
- Fan hits shroud
- Ceramic coating on headers?
- Outer heater box
- Recommendation - 72 350 spark plug wires?
- What are these wires?
- Removing a stuck bolt
- What is a 1969 W31 W30 exhaust heat riser pick up worth?
- Charlotte AutoFair/Mid Atlantic Olds
- Setting gaps on the trunk lid
- vinyl top code on 71
- 307 Olds Powered 1985 Buick Hearse
- 1961 Olds S-88 convertible bucket seats
- Hot Rod Power Tour 2018 - anyone going?
- 2019 and 2020 national locations
- Rebuilt power window switches
- 61-63 Firewall stamps
- 67 Vista Cruiser Door Sill Plates
- Diameter of 68-69 Rally Pac Gauges
- 69 dearborn/phord trans help
- Lower ball joint
- Audrain Automobile Museum
- Current carburettor castings
- Bushing
- 67 442 Vintage Air
- refeences for a dist. rebuild
- Installing original 72 cutlass radio
- Steering box rebuild
- Raised white letter tires
- 67 Cutlass Cruise Control Parts
- 69 W 31 and W 30 air ??
- Clear Anodize Service
- orig water pump??
- Stock color trunk spatter paint
- Tire size 71 Cutlass ? 255-60-15 ???
- Caliper Covers
- Amazon gift showing on screen constantly
- Cowl Tag Decode
- Olds J2 vacuum switch
- Anybody familiar with this car ?
- Anyone in Daytona Beach Area to look at a 442??
- Who knows early to mid '50s parts well?
- Rag Joint
- Is a smaller waterpump pulley a problem??
- weatherstrip/rubber moulding manufacturer's
- 375 hp production numbers in '66 and '67?
- ebay advice needed
- 69 vs. 70 Hood.
- First curved glass windshield?.
- New ride - 2015 Camaro Convertible RS
- Floor pans
- JJ Best Banc & co, collector car loans, Any experience here?
- 70 442, window crank handle knob Color
- which trans and rear to use.
- 1970 OAI base
- 1970 442 seat spring
- 67 supreme disc brake bolt on suggest?
- Rivets for VIN Dash Plate & Cowel
- Old seat covers
- Sad demise of the CCRider (1992 Custom Cruiser(
- Where is my horn relay?
- Vintage Air
- 1970 Cutlass Supreme Convertible - value after restoration
- Mallory Hyfire 6AL no start except in the key on position with GM HEI
- 67 Cutlass Firewall
- Reproduction or NOS?
- '68 442 on Ebay
- Wanted - Information Whereabouts Of 1969 Oldsmobile MSU Race Car - $10000
- Goodmark OAI hood...
- What do these escutcheons go to?
- Do I need this carburetor adaptor?
- comparing thermostats
- Springs on all the corners
- I need a picture or diagram of the a/c brackets mounting.
- Discount codes
- Oldsmobile vs Chevy vs Buick
- Tampa/St Pete Olds people
- igniton switch 64 Olds Dynamic 88
- Aftermarket Wiper Arms
- Article in Hemmings about Oldsmobile Museum.
- Aftermarket Wheel opening moldings 70 Cutlass
- Value of 425 and 455 - General Info Needed
- Help i.d. of 4 speed pedals, 1973 442?
- Should my 67 Vista Cruiser have a fan shroud??
- Did the 70-72 442 4 speed consoles have a working light inside
- 1970 Delta 88 Royale on ebay
- 13th Annual BOPC show, May 19, West Chester, PA
- Kick down cable
- Rear seat corner side panels ????
- Trunk release button location '70 Cutlass
- 71 442 What did you guys think of this car
- Halo top replacement
- vent window seal-
- and then there is this!!!
- Gas tank painting or coating
- Yet anonther "can you decode this for me" thread
- Rear seat insulation installation.
- Convertible A Pillar Pads
- 70 Cutlass sx convertible MIA
- 1955 Olds super 88 4dr sedan. Build it or part it?
- Black Oxide finish
- 1970 w-30 ?
- '64 442 4 speed
- heavy duty cooling
- KC to OKC parts pickup
- Fuel sender question
- 66-67 Dash Removal pictorial
- Buyer beware
- Suggestions/help to get parts shipped
- Noisy hubcaps (wheel covers)
- Should I have a cross flow or down flow radiator?
- Jetfire number 4, Another adventure
- Right lower ball joint
- 69 W-31 engine
- 1970 442 Conv' 4spd w25
- Front springs installed
- 1970 442 Oldsmobile Indy Pace Car
- 94 cutlass supreme convertible
- '70 Cutlass dual exhaust pipes - suppliers?
- Eldorado brake calipers
- 1970 cutlass factory options !
- 31st annual Coming Out car show
- What is considered high performance
- 1958 j2 vacuum source
- Wheel Alignment Issues
- Help Identifying 1970 Cutlass Convertible Parts
- 1966 442 - Valve Cover Decal
- il bopc swap meet
- 1966 442 carb
- 70 442 heater core seal
- Weird coating on sockets
- Lynn Welfringer scams another customer
- Any members near Abilene?
- stainless trim 66 holiday coupe
- Question for the Guys Who Worked at the Factory Back in the Day (1970)...
- Most Interesting Job
- 1970 Build Sheet
- Who had the most Med bills last year ?
- Hey AZ.
- High School Nationals in Norwalk W-31
- Shifter?
- Owens Corning OAI Hood advertisement 1970
- First production car in space
- Anyone recognize these plates? Illinois OLS FAN 2
- Can Anyone Take Measurments of The Width of the Pleats on Their 1970 '72 Bench Seats?
- 2 69 GTO Judges spotted rotting away
- How do I find the compressed thickness of a head gasket
- 1970 w-30
- 1970 Ram air holes in tunnel
- Mechanical Fuel Pump Replacement Question
- 1974 toronado 455
- Saw some cool Olds today
- Engine Mount Rebuild by Damper Doctor
- Pillar Post Pads for 68 Cutlass S 2 Door Post
- 1966 442 convertible cowl tag
- 1967 442 article
- hood hinge rebuilders
- 1970 2 dr post rallye 350
- AC Valve cover breather ????
- oldsrocketparts.com
- 1970 8 track player knobs
- Change in antique class in Saskatchewan Canada
- 1974 toronado 455
- 1966 442 automatic transmission
