350 - JM 20- 22 cam results
Hey all, so I've had my 350 in place of the 307 for a few months and it has about 4k miles on it now. I wanted to do a quick follow up on how it runs and drives. It's a factory 70 4bbl engine with only the following mods, the cam, adjustable rockers, and a hughes 2500 stall converter with a turbo 350/ transgo reprogramming kit. Oh it also has thornton 350 jrs and 2.5 dual exhaust, no h or x pipe. I will say I was alittle worried about poor vacuum but this isn't the case, at idle it feels like a factory cam with a slight lope. As for driveability when cruising around town casualty, it feels pretty much stock wich is what I was going for as its an every day use car BUT when you get into the secondarys (quadrajet) this thing pulls hard through the rpms. I haven't brought it past 5k and I don't ever plan to (not sure of the redline).
I'm unsure what I have for rear gears but it runs at 3100 rpm cruising steady at 90mph with no overdrive. It's a 1990 buick estate wagon (4400 pound B body). Also it was a factory 310 horse motor but I have no clue what it's at now. I can't imagine doing just a cam did much to add alot of power but it deffenitly shifted my powerband into the higher rpms. Maybe some of you have some thoughts on this.
Here's a video of it running.
I believe a 2.93 was the standard gear in the 8.5" rear in the wagons, 3.23 may have been a option. What is it idiling at? What does the Hughes converter stall behind your 350? Even my 214/214 cam is noticeable and definitely prefers a higher stall with the 2.78 gears.
oldsonharmont
January 21st, 2009 05:22 AM
olds307owner
May 17th, 2007 07:48 PM
