PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. New member. ‘72 Delta 88 Royale Converttible owner
  2. Two-Tone / Data Plate
  3. Look what rolled up in the parking lot at work today...
  4. Header Install
  5. Block to head pins
  6. Will 1968 442 new seat covers fit a 1967 442 seats
  7. Starter recommendations - Olds 455
  8. Hard accelerator pedal
  9. Engine Detailing
  10. cold start fast idle 93 3.4
  11. Trim tag decoding
  12. Oil pan touching frame
  13. 2019 oca nationals - restriction
  14. Dealer built cars
  15. Front End Bushings?
  16. UAC A/C Compressor & Component Kits
  17. Turn Signal Troubles
  18. Vintage Air Installer Washington State, California or Arizonia
  19. 98 -65 windows question
  20. Drum brakes
  21. 27th Annual Devils Run car show
  22. 70 w-30 ebay scam?
  23. ?????????????
  24. OAI air cleaner spring photos
  25. Carriage bolt source
  26. 4-27-2019 on site auction in Pinetops NC
  27. Labor of love...
  28. 455 cid long block questions
  29. Rons Classic Cutlass
  30. Vintage hurst test 1968
  31. Canadian trim tag
  32. 455 olds in buick skylark.
  33. Somernitescruise
  34. 64 Starfire Top Radiator hose
  35. find of the week
  36. 1940 Oldsmobile Custom Cruiser
  37. Spring Carlisle
  38. Rag joint rebuild, rubber disc
  39. Door Panel Questions
  40. Cutlass / ElCamino
  41. 72 Cutlass Supreme (Rear Qtr. window roller springs missing)
  42. Built 350 getting too hot at idle in gear...
  43. Oldsmobile Parts
  44. Time for a new car for the wife.
  45. Repro drip rail trim for 69 cutlass
  46. I always wondered what these were for...
  47. R4 compressor clutch puller?
  48. Want To Buy 59 Olds 98 Holiday Scenic Top or Convertible
  49. Replacing rollers on the front windows 68 442
  50. Winter Garden Cruise In
  51. Cowl Tag 997
  52. 1970 pace car hood question
  53. Looking for a "S" emblem for my 68 convertible trunk lid but only see listings
  54. ready for the road
  55. Sacramento Swap Meet
  56. buick v6 in a firenza
  57. 2 Delta 88’s Found
  58. Ron's Classic Cutlass in Indiana
  59. 72 Cutlass Oil Fill Cap Color
  60. 57 olds power steering pump
  61. Obscure Bench Seat Hardware
  62. Anybody else with a 2019 Ram 1500
  63. Tricky question: Does front bench center arm rest have vinyl or fabric as pictured?
  64. Question for a Hurst Dual Gate Expert
  65. HVAC hoses
  66. Holley fuel pump installed
  67. Is there an Oldsmobile color?
  68. Gas overflows, what's up???
  69. '66 Front Lower Control Arm - Rearward Bushing
  70. 1969 Rear Window Defogger
  71. 1969 Right Side Door Mirror Install
  72. 1970 W-31 Registry
  73. Fuel Sending Unit problems
  74. First Show of the Season Next Week.
  75. Neon lights
  76. A tad surprised to see a 70-442 W30 vert
  77. Hydraulic Engine Lift - Which to buy?
  78. MPG? I know, dont buy a 442 for mileage,but
  79. Edelbrock 065 dual quad setup
  80. 72 CS Clock help please
  81. 1968 442 convertible what's it worth?
  82. '70 Cutlass ash tray - zinc plated?
  83. Factory Oil Pressure Gauge Accuracy
  84. Really?
  85. Carb cleaning tips needed
  86. Breaks
  87. Keyed power source
  88. Great Service from Everyday Performance
  89. Air cleaner I.D.
  90. 1970 olds tach wiring help.
  91. Under hood oai screen
  92. differential covers
  93. 72 CS Seat/Shoulder belts ?????
  94. Does anyone know where these go?
  95. Looking for magazine article - '71 W30 vs. '70 W30
  96. CLANK! Random parts fell out of 64 Jetstar
  97. Crate engine
  98. Hurst Pro-matic 2 shifter
  99. Bought a Firenza
  100. Peak molding clips
  101. The Part Giy
  102. Anyone from canuckistan?
  103. First show of the season
  104. Canadian Window Sticker
  105. Oldsmobile Torque
  106. 1968 Olds wiring harness
  107. '54 98 Deluxe Search
  108. 69-70 hood question
  109. temp guage reading vs radiator temp
  110. Another Jetfire parts car
  111. Help with window alignment with weatherstrip
  112. Quarter window metal track
  113. Good Transmission Shop in Mass.
  114. Found a 64 cutlass
  115. Did they ever put a three on the tree manual transmission on the 1973 Cutlass?
  116. New back seat top and bottom
  117. How many Ws are there?
  118. Lost all oil pressure
  119. Leaky Moonroof
  120. convertible conundrum
  121. Hood lamp installation ....
  122. 72 CS Dash Speed Nut Needed
  123. What should club post?
  124. 72 CS Window felts
  125. Get low
  126. Carpet color choice for a '65 Cutlass (looking for knowledge)
  127. 72 Cutlass for sale(NOT MINE)
  128. Horn Location
  129. Help Ship Wheels to Canada
  130. 72 CS trunk divider board
  131. Fuel sending unit
  132. Tri-Carb Restorer
  133. 307 olds in a firenza
  134. Private investigator needed in Boston area
  135. Please help with radiator measurements
  136. Replacement RADIATOR
  137. Header-steering lock rod interference
  138. Craigslist find became even sweeter!
  139. Transmission cable
  140. Pacific Gbody serpentine conversion
  141. Strange noise, help needed...
  142. pillar post
  143. cleaning the convertible top
  144. Exhaust cutouts?
  145. (1972 Delta 88 455 Hot Start Problems
  146. Package tray jute question
  147. Quadrajet 403/350
  148. 350 Main Bearings
  149. Repro Battery Tray ID needed
  150. 1971 Cutlass Club Coupe
  151. 69-70 Hood Differences
  152. Part ID Help!
  153. anybody else see this 2k mile 70 w-30?
  154. Any value to Jetaway transmission?
  155. W30 F heads
  156. Bumper/fender brace discussion (continued)
  157. 324 build for a 66 CS?
  158. RePop Crap Strikes Again 72 CS
  159. Does anyone have an old Wagner brake catalog?
  160. Need advice on a posi unit for a C body
  161. Searching vehicle history 13 digit VIN
  162. Distributor Restoration
  164. What is it from???
  165. And here I always thought they started making Toronados in 1966
  166. Th350 kick down cable?
  167. Fender Weather Guards?
  168. 71-72 fenders on a 70 cutlass/442/F85
  169. First run of the year
  170. Are classic car dealers ruining the market for buyers?
  171. Questions about adding Vintage air to my 71 Cutlass
  172. Curious if anyone has a custom dash in their car?
  173. How do the Front Fender Moldings engage with each other on a '68 to '72?
  174. Did some clean up work...
  175. 1972 Cutlass Windshield Washer Jug Screws
  176. what to do with W-30 intake after cleaning
  177. We've all seen the threads on the '68 stripes...
  178. New Music Video featuring a 442 & Superbird
  179. registration question
  180. through the looking glass
  181. Any Good trick to snapping the waistline outer door moldings over the plastic clips?
  182. To flush or not to flush trany
  183. Roadside toolbox
  184. Production numbers
  185. 1970 Colored Vacuum Hoses
  186. Dash Cams-Whose got'em?
  187. Looking for a 400 olds engine
  188. Service Replacement Blocks
  189. 70 headlight surround to grill bolt or screw
  190. Jackie Cooper Oldsmobile trunk emblem
  191. Score!
  192. 1962 Starfire convertible fuel tank
  193. Barrett Jackson Shock
  194. Check Your Parts When they Arrive
  195. Anybody going to Daytona this weekend ? Mar 22-24
  196. gaskets
  197. 67 Cutlass Question?
  198. Misrepresentation or Outright Fraud, or Both?
  199. More Mecum Malarkey
  200. Name That Air Cleaner!
  201. Adding fun stuff to stripped down 442?
  202. 1967 Cutlass 442 with column shift
  203. Car Shows
  204. 1975 omega worth?
  205. Aaaaauuuugggghhhhhh!!!!!!!!!
  206. Need opinion yay or nay
  207. 70 442 w30
  208. Identify please
  209. Ever Seen this 442 Before?
  210. Secret pontiac?
  211. Choice of Oil for older 50's motors
  212. Treadle vac
  213. Looking at a 1968 Olds 98 parts car, boxed frame?
  214. Researching Bob Voss’s 1968 442
  215. Restoring the texture on an aluminum intake
  216. Test for the gm parts gurus
  217. Promotions & Rebates at RockAuto.com!
  218. What's the method for debating the veracity of an ad?
  219. Concept car?
  220. If anyone is down my way (SE VA) the beginning of May...
  221. New paint screw up
  222. Torque Converter and Rearend Ratio
  223. Car Show in Burbank, California
  224. Rock Auto Strikes again
  225. ID Manual Transmission
  226. What is this actuator?
  227. 32nd annual Coming Out Car show
  228. 70 W31 just purchased in rare colors
  229. 70 Taillight Housing discolored- How do you fix
  230. Images of 1967 Cutlass Cruise Control
  231. VC310 Standard Distributor Vacuum Advance fits what
  232. Gmc rv's with Olds hearts
  233. 67 Wagon Trim Tag
  234. 71 Cutlass Sport 350, Runs BAD when warm
  235. 1969 sport wheel center cap repop
  236. Finally finished - 1968 Cutlass Supreme W-31 tribute
  237. Got my gas cap finished...
  238. 67 Cutlass radiator support
  239. Took my Olds to It's first car show
  240. 1974 VSO Cutlass
  241. Gilmore car museum all-olds show
  242. 65 cutlass tail light socket
  243. 14th Annual BOPC show, May 18, 2019 West Chester, PA
  244. Charlotte Auto Fair
  245. What to do when you loose steam?
  246. 82 olds parking brake cable install
  247. Who here remembers “Reflections” magazine?
  248. Tweed goes Hollywood
  249. Shifter rubber boot question
  250. Anyone near Chino, CA? 1972 knowledge a big plus.
