Restoring the texture on an aluminum intake
Old Mar 15, 2019 | 06:51 PM
danktx's Avatar
I have a Edelbrock Performer 455 manifold on a motor that I would like to remove the 455 lettering and recreate a texture like the surrounding surface. How would I go about this? Is there any way to just do the quarter size spot where the 455 was removed? I'd like this to be invisible if possible.
Old Mar 15, 2019 | 08:06 PM
Gerald Nickels's Avatar
Just give it to Andy he will fix it for you.
Old Mar 15, 2019 | 08:21 PM
don71's Avatar
same but different
If I were to attempt this, I'd start with a grinding burr in a die grinder. Next, some work with a medium grit cartridge roll and finally finish with abrasive blasting, probably sand or a similar product. It might need to be done on the entire surface of the intake to look uniform. Keeping uniformity of the as cast texture appearance would be the goal.
Old Mar 15, 2019 | 08:43 PM
OLDSter Ralph's Avatar
I would do this, with exception..........
Tape off around the area with a TRIPLE layer of adhesive tape that you are going to remove material. If the die grinder gets away from you, "no marks".
When you get down close, use one layer of adhesive tape, and use a "Mill Bastard" file to smooth it, using the adhesive tape as a guide.
Use a 1" or 2" "Rol-loc" (3M) 280 grit sanding disc to blend. A right angle die grinder is easier to control at this point.
Use large media (round sand/glass beads size230) with 40-50 psi air pressure to "re-texture" the area and fade into surrounding area.
........Just my two cents worth.
Old Mar 16, 2019 | 06:03 PM
danktx's Avatar
Thanks for the info. I like your suggestions.
I'll let you how it turns out when I get to it.
DanK
BAFRAYD
Feb 17, 2015 09:01 AM
ankerclanker
May 18, 2014 06:52 PM
bobb
Oct 4, 2010 06:02 AM
Lady72nRob71
Jan 7, 2009 07:51 PM
sethj78
Aug 13, 2008 10:56 PM
