ID Manual Transmission
Richmond four speeds come in at least four different varieties , depending on low gear ratio .
The various low gear ratios are 2.43 , 2.64 , 2.88 , and 3.42 to 1 low gear .
The transmissions are identified by "rings " or radial grooves cut into the input shaft splines .
Count he number of those or post a clear pic of the input splines and someone can ID it for you .
The casting number means nothing . All Richmond T-10 's use the same case .
