70 Ring gear question
Old Jun 3, 2017 | 06:27 PM
67Rocket's Avatar
A 70 olds cutlass open rear with 42 teeth on the ring gear would be what ratio? Thanks
Old Jun 3, 2017 | 06:33 PM
Qwik71442's Avatar
Full-time Taxpayer
42/13 3.23??
Old Jun 3, 2017 | 06:38 PM
If you have it open to count the ring gear teeth, it is very easy to turn the gear to see the numbers stamped in the edge of the ring gear. That will have the number of teeth on the ring gear and the pinion gear. Divide the two numbers for the ratio.
Old Jun 4, 2017 | 07:26 AM
Or, count the teeth on the pinion and do the math.
Old Jun 4, 2017 | 08:28 AM
67Rocket's Avatar
That's what I thought, just wanted to check with the pros. Thanks
Old Jun 5, 2017 | 07:15 AM
monzaz's Avatar
3.23
3.23 should be 42 RING.... everything else is 41 or 40 or 39 etc. from the factory
oldspackrat
Aug 10, 2014 10:03 PM
costpenn
May 10, 2013 06:11 AM
Bandit Banana
Jul 14, 2012 07:13 AM
fabcraft
Nov 12, 2011 11:15 PM
idaholc
Apr 13, 2009 01:33 PM
