67 Cutlass Question?
Old Mar 18, 2019 | 04:44 PM
67 Cutty's Avatar
Question 67 Cutlass Question?
I was wondering if the parking lights on my 67 Cutlass are soposed to stay on when the headlights are on, or are they supposed to turn off when the headlight switch is pulled all the way out?
I'm thinking they should stay on , but just wanted confirmation from another owner. Thanks,
Joe
Old Mar 18, 2019 | 05:05 PM
They only illuminate in the headlight switch parking light position, 1st click. They turn off when the headlight switch is pulled to the headlight position, all the way out.
Old Mar 18, 2019 | 05:35 PM
67 Cutty's Avatar
Good to know... thank you Sir!
(one less electrical problem to solve) lol
Just picked up the old girl, and she has a few gremlins to work out but lots of potential. 67 Cutlass Supreme, 60K original miles, 330ci 4bbl, Power Glide. And so it begins.....
Old Mar 18, 2019 | 05:50 PM
OLDSter Ralph's Avatar
You don't have a "powerglide" unless someone transplanted it.
Old Mar 18, 2019 | 06:10 PM
As stated above you have a Jetaway (ST300) transmission with a switch pitch (variable vane) torque convertor. There is a switch on your firewall carb linkage that controls it.
Old Mar 18, 2019 | 06:38 PM
67 Cutty's Avatar
Well then, that is even better! I always thought the old Jetaway 2 speed was your basic Powerglide. (GM family) I knew the switch pitch was available on the TH400's but did not realize it was possible to get on the 2 spd auto's.
I will have to investigate this tomorrow. Something tells me this is not hooked up as I don't remember seeing the swich on the throttle linkage?
Old Mar 18, 2019 | 06:45 PM
All automatic 67's had them, there should be a 3 wire switch as part of the linkage pivot.
Old Mar 18, 2019 | 07:02 PM
67 Cutty's Avatar
Yep, sure enough! Just went out to the barn and confirmed. Big rotary switch on the linkage by the firewall.
So, out of curriocity, what is the "performance" stall speed on these converters?
Old Mar 18, 2019 | 07:17 PM
If I remember correctly it was 1800 and 2300.
brianbeez67
Care and Appearance
Apr 25, 2017 07:14 PM
Moistus
Jan 27, 2015 05:06 PM
Thybigwheel
Jun 21, 2014 12:35 PM
Niko
Jul 24, 2013 10:09 AM
Sid
Sep 29, 2010 02:43 AM
