PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. What's wrong with this picture?
  2. 62 Starfire firewall grommet
  3. Demmer “The Rectifier” Olds
  4. Fuel Tank
  5. Today I learned...
  6. 70 442 steering gearbox leaking
  7. 57 or 58 olds which do you prefer?
  8. 442 emblem stencil pattern available
  9. 371 Rocket innards
  10. Need mirror glass mounting help
  11. Piston cc’s
  12. A DC-6 came in for a landing!
  13. To delete heat riser valve or not? 1965 Big Block 425ci
  14. Gauge Lens Cleaning/Polishing
  15. A/C delco belts - worth the extra $$?
  16. Any good classic Chevy Truck forums?
  17. New is not always good
  18. Power steering leak? Something else?
  19. We’re did my car come from?
  20. 84 Delta 88coupe without vinyl top?
  21. 455 F/Fa Blocks
  22. 64 Cutlass Coupe window chanel
  23. Need Help Identifying a motor plus need help with info on parts.
  24. To paint or polish Vin
  25. 65-66-67 four speed battery tube bracket
  26. 1969 442windshield wipers
  27. 1972 Olds Toro hood release T Handle for sale???
  28. Help identifying power seat track. Early 60's full sized?
  29. Timing questions, initial, mechanical and vacuum advance
  30. In take manifold
  31. 1970 Cutlass S Defroster Door Screw Placement
  32. 68 Cutlass Designer Selling His Cars
  33. H/O on Roadkill
  34. Distributors
  35. Check out this Jetstar I.
  36. Want Clean Nuts?
  37. Valve cover breather removal.
  38. 70 442 quarter window trim needs re-glued
  39. GAS CAP ID What year and model used this one?
  40. Y74 pace car
  41. Package tray
  42. Tire dillemma - size vs cost vs ride/handling
  43. Vista Cruiser Handles Like It’s On Rails
  44. What is this Power trunk release for?
  45. Polish, polish and repeat
  46. Trunk lids
  47. Rag joint grounding wire.
  48. Seam Sealer? Panel bond goop experience?
  49. Steering column
  50. Looking at a 68 Toronado
  51. Evap canister filter replacement question 🤔
  52. 69 442 Carburetor Numbers
  53. need to ID Rocker Moulding
  54. Glass kits
  55. 55 mph
  56. 57 olds clock
  57. 1964 Jetstar and Starfire frame swap
  58. Cool 1970 Cutlass Supreme
  59. Redoing this engine bay
  60. 1970-1972 Console lock bezel removal
  61. My friend hooked up my valve covers
  62. 1972 Olds Toro dash Clock removal
  63. Door snd trunk locks
  64. door panel install help
  65. QA1 Coil Overs Big Block vs Small Block
  66. Vin stamp. 68-72 block 455
  67. Found a few cars near Oklahoma City.
  68. Windshield for 71 Cutlass convertible
  69. Oil cap fix?
  70. Open air cleaner
  71. Oldsmobile Art Glass
  72. Valve covers ('69 442)
  73. North Carolina Convertible Top Installer
  74. Silver paint for grills
  75. 17th Spring BOPC Car Show, May 20, 2023, West Chester, PA
  76. Oldsmobiles at Chicago World of Wheels
  77. 1993 Olds Ciera 3.3L + Best Coolant Flush Advice
  78. 71cutlass supreme column length
  79. Hood Emblems
  80. 1968 rear main seal
  81. Opgi?
  82. Spare?
  83. 25th annual BOPC show Mesa, AZ
  84. I dropped my 9/16 socket
  85. Shock oil weight?
  86. 1970 Tornado Standard Non W34 Valve Size
  87. 1956 oldsmobile Fiesta spinner hub cap
  88. Keep coolent in engine during hose change
  89. 394 vaccum
  90. Alternator suggestion
  91. 1971 442 w30 wheel color
  92. Olds Ad 1961 cutlass
  93. Spiting out Coolant
  94. 1967 Oldsmobile 98 front bumper removal.
  95. Vinyl top care
  96. It's the little things...
  97. Window cleaning tips
  98. !970 Cutlass S Center Dash AC Vent Assembly
  99. 1968 bumper scoops
  100. Push rod length still!!!!!
  101. Heritage Center missing Olds info
  102. Am I nuts...body off or no?
  103. 64 65 66 67 GTO (A-Body) Inner and Outer Tie Rods Needed
  104. Alternator Restoration & Applications
  105. Picked up this very original 66 4 4 2 for a member
  106. 1971 Cutlass A/C System
  107. 67 repop dash tip
  108. 71 Cutlass Supreme Convertible 4 speed
  109. Is it just me or is this cool ?
  110. Good lord there is some JUNK being sold today!!!
  111. its always somethin'!
  112. Seeking Assistance/ Gas Nozzle not Fitting Filler Neck
  113. 70 W30 CARB 7040258 Boiler 81
  114. 1972 Oldsmobile Toronado 455 hard cold start issue
  115. Brake master cylinder tag
  116. Mystery red
  117. Quadrajet experts needed
  118. How to package 67 hood & trunk lid mouldings for mailing
  119. Buying used, non-classic
  120. Shocking Blast Cabinet
  121. Starting Problem
  122. Repop Supreme 1/4 ext. gaskets correct?
  123. 1970 olds f85 6cylinder what color is the engine ??
  124. BOPC Swap Meet
  125. 56 Olds Fuel Gauge NOW working!!
  126. Radiator Springs - needed or not?
  127. Awesome oppertunity!!!
  128. TRW 2112SS timing set cross reference
  129. Gray colored a6 a/c compressor
  130. Protecto-Plates are the Key
  131. 1964 4-4-2 on eBay
  132. !979 Cutlass roof rail, weatherstrip etc instalaltion details wanted
  133. 1970 442 AC Compressor Rebuild Service
  134. 68 442 with factory disc brakes
  135. NOS Steering Wheel
  136. steering stabilizer
  137. Delmont 88 in CT junkyard
  138. Help identifying some Mondello parts (pulley/brackets)
  139. 442 stripes
  140. Best Oldsmobile Code Resources
  141. Fuel Pump 455
  142. Car Dolly...any ideas?
  143. Spiral shock rebuild
  144. Break in oil question
  145. How much exhaust clearance over axle?
  146. 1970 442 console lock assembly removal
  147. Any interest in a replica Harrison ZR tag?
  148. Emergency Brake Cable Routing
  149. Inside Hood Lock
  150. New Purchase - 1994 Cutlass Supreme Convertible
  151. What do these numbers mean?
  152. 66 Toronado carb fire?
  153. Chemical Guys products
  154. 1972 Oldsmobile Toronado 455 with power steering and AC, main Drive Belt tensioner lo
  155. Clutch return spring kit
  156. Hood Pins
  157. Model Car 1971 442 W30
  158. Kit to reline your own brake shoes, 42-48 Olds
  159. 1968 Cutlass Sports coupe
  160. 1972 Oldsmobile Toronado starter relay location
  161. Scan tool say unable to communicate
  162. Any thoughts where I can buy a longer version of this bolt?
  163. Prefab metal garage
  164. Hood insulation
  165. Dropping driveshaft for rear pinion seal, and then th400 rear seal leak
  166. '64 394 to a '50 Hydramatic
  167. 394 rocker shaft length?
  168. Need help identifying correct air cleaner for a 1966 Olds 88
  169. Aronado
  170. Note to self, Speedo cleaning / restoration
  171. What old relics have you found in your old relics??
  172. Rear window molding and clips and extra ground wire
  173. Extra Bracket from build, 70 Cutlass SX
  174. How to post videos
  175. Any Phoenix Az members
  176. Phoenix/Tucson area car events Feb 5- 10?
  177. Joe P always says....
  178. Introducing Project Olds-Camino!!
  179. Exact Detail 1970 Olds 442 W-30 convert Agean Aqua diecast
  180. Saw on craig's list. The start of the REO lawnmower.
  181. Factory-correct Restorations vs Restomod values in the new Artice by CARiD
  182. ‘55/‘57 Manifold ?
  183. 71/72 blue steering column paint
  184. Hacker Alert
  185. Fuel return line 72 Cutlass
  186. Central Fla.Oldsmobilers car show Feb 4th
  187. Antique Automobile Article/Eric Jensens Jetfire
  188. Back Panel seat retainer clips
  189. Does your Oldsmobile have an alarm?
  190. 200 4R mods
  191. 1971 Cutlass hoods
  192. TH350 or TH400
  193. Yes, we have no bananas
  194. '77 Supreme at Mecum
  195. Suggestions for Convertible top Installer central CT
  196. Engine experts, Engine vacuum at WOT
  197. 1968 Chassis Service Manual binding
  198. 72 442 Grill Replacement
  199. You read threads for entertainment??
  200. Mecum results very mixed
  201. 1948 thru 1951 compass
  202. What do you think about this one…
  203. Rocketman
  204. Color choice ?
  205. Mecum Saturday
  206. What to do
  207. 80k for a clone & doesnt sell
  208. Remember these?
  209. Adjustable vacuum advance
  210. Hmmmm. 1970 conv 442, fairly original and unmolested, at Mecum Kissimmee.
  211. Replacing Motor&Transmission Mounts
  212. Caliper casting numbers
  213. Oldsmobile Dealer sign
  214. 70 Cutlass my next project
  215. check part number 22049544
  216. never to early to sign up
  217. Keying out vintage parts
  218. Something doesn't look right...
  219. 35m20 code?
  220. Convertible top pump pressure.
  221. Best cleaner for oil stains?
  222. Is Anyone going to Mecum/Kissimmee ?
  223. Fuel Pump - Tri-Carb
  224. 1971 Cutlass Supreme Glovebox Hinge
  225. Am I reading this right?
  226. Spring/Fall Carlisle/Hershey, I am confused
  227. Good or bad advice ??
  228. Carb lift plate
  229. Interchangable Distributor?
  230. D and G chrome plating in Cincinnati
  231. None of the V8s I've owned compares with the Old 455
  232. Found this down the street from me…1956 98
  233. 1971 Cutlass-not happy with the close ratio steering box
  234. AC on my 1999 Oldsmobile Intrigue blows hot air
  235. Alternator whistlng
  236. Someone looking for 68 front fenders
  237. choosing a carburetor
  238. Car Storage Question
  239. Power Seat Track Info Needed
  240. Good News From eBay
  241. Automotive History Preservation Society
  242. 1971 cutlass supreme header questions
  243. 1967 442 Convertible barn find
  244. The Ian Cars Are Coming.
  245. fuel sending unit 68 442
  246. How many lug nuts on a 37 66?
  247. RE Olds Transportation Museum
  248. Anybody recognize these?
  249. 2023 Olds Nats Dayton, Ohio.
  250. What bolts do I need for this?
