Alternator whistlng
Alternator whistlng
I have a 70 cutlass 350 that has a slight but annoying whistle at idle. When I remove the alternator belt the noise disappears. So I replaced the alternator and belt( fusick ). Whistle still there. Next I replaced the water pump. Nothing. Next the crankshaft pully. Still nothing. Also replaced the voltage regulator, positive batterycable, battery and stranded engine ground which was missing. Seems to get louder when I turn on the headlights. Goes away when in drive with foot on the brake. Any thoughts?
Thanks. Just wondering if I need to drive it for a while and let the battery fully charge and let the alternator break in. I’m baffled because Fuscik always has quality stuff and since it’s the same noise as the previous alternator. Frustrating!
It's tough determining what a "whistling" sounds like. Everyone may have a different opinion - a squeal, a high-pitched whistle, low-pitched, etc. - constant whistle or intermittent? I'm posting the following ONLY to help understand what the whistle sounds like (regardless of any viewer comments on the video). Does it sound like this video? Constant, intermittent? High-pitch, low-pitch?
Whine is nothing as bad as the video. Just let it idle for about 20 minutes. Whine eventually mostly stopped and greatly reduced when I turned on the headlights. I’m guessing the new battery has to fully charge and maybe the new alternator break in. Hoping. Thanks again for responding .
I suspect the whistling will stop after you drive it several times. If it were bearings I suspect it would be loud and continually very noticeable. I've replaced a newly rebuilt ALT & upon start up for several days it whined for 5-6 minutes (at startup). Noise stopped under load i.e. in DRIVE with foot on brake and couldn't hear a thing while driving. It did this for 5-6 days and finally the noise was completely gone. Take it for some drives for a week or so. I'm hedging under various loads of normal driving the noise will be gone. Ensure you have the ALT belt tightened correctly. You should have ~1/2" movement - you can tighten them pretty snug.
