PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Hey Allyolds, Bill T, Etc - How's Your Weather?
  2. Two most recent pics of my big metal babies
  3. Carter 4 barrel
  4. walbro fuel pump 838 With pressure regulator
  5. Bucket seat stud mount dimensions
  6. feel like I'm missing an arm
  7. Smokin Mustang Vid.
  8. Door panel bezel
  9. location of fuse block
  10. Repairing the rear lower tail light socket on 67-442
  11. Engine swap
  12. ? for fellow 57 olds owners
  13. Tranny Swap with a Twist
  14. 324 olds
  15. Getting ready to pull engine.
  16. removing trunk light from 1967 Cutlass
  17. Ranking Oldsmobile heads
  18. Dash Pad Cover - Any Good?
  19. 71 Cutlass Engine Problem
  20. Try this instead of replacing your original radio
  21. Mag Hytec transmission pan
  22. Basic Troubleshooting lighting issues
  23. Ok, need help....
  24. 67 cutlass
  25. '70s car phone wanted.
  26. See if this dosn't tighten your lugnuts
  27. Gm tools
  28. Olds Bottle Opener
  29. exhaust bolt/stud threads into water jackets?
  30. 1961 88 headliner removal/install
  31. can this be fixed
  32. how to remove washer?
  33. Wicked Vist!
  34. Friends don't let friends....
  35. Craigslist 1978 Mid-engine 442
  36. EGR Valve
  37. What did I find under carpet? Build Sheet?
  38. 64 442 Field Test Car, Really?
  39. 1972 Olds 2dr Hardtop Questions
  40. Motor Trend 1970 Vista Cruiser
  41. New 72 spoke Wire Wheels for my 59 coupe
  42. Our 1970 Olds Ninety Eight arrives in the UK!
  43. The new and the old
  44. Heater recommendations for heating area of large pole barn
  45. Speedometer Circuit Board Question ???
  46. Semi Tubular Rivet Tool
  47. Sport steering wheel problem
  48. Veterans day
  49. 1971 W-30 4 speed convertible
  50. fuel mileage for 455
  51. iPad Air 2
  52. 2000 Intrigue front bearing/hub stuck!!!!
  53. The 63 Starfire is home
  54. 68 cutlass s
  55. Vehicles needed for 2015 EyesOn Design Exhibition - June 21, 2015
  56. Tail/Front Turn Lights
  57. Using up 2 pontiacs
  58. Snake Oil?
  59. 65 Cutlass/442 Dash Picture
  60. 1961 power brake booster
  61. 1961 394 lifter noise
  62. I found something yesterday...
  63. afternoon project.
  64. Pretend-mobile?
  65. Instrument Panel Restoration
  66. 1961 Starfire transmission question
  67. These Rallye Are Growing On Trees
  68. The Houston AutoRama
  69. Back in an Olds!
  70. Probably been asked - Quality of The Parts Place Inc.
  71. First cutlass
  72. Electric fans Part 2
  73. fighting with the parts place
  74. Anyone like to haul my cutlass?
  75. Can't solve the squeal/Hesitation
  76. 69 cutlass 350 v8 oil pump question
  77. 1157 light bub removal on '67 442
  78. So I guess I'm writing a muscle car book....
  79. #'s#'s#'s#'s
  80. 66 442 A heads or B heads
  81. Craig AM-FM-cassette speaker wiring
  82. Been Cruizin
  83. Craig AM-FM-cassette speaker wiring
  84. 1970 Cutlass Antenna
  85. mild performance build
  86. EFI Question
  87. Help, I'm becoming a muti-millionaire
  88. under hood screen
  89. 442 question
  90. Treasure hunt
  91. Bucket seat,floor shift option on W 31
  92. 1970-71 Oldsmobile production figures by color
  93. I bought another car, well, it's actually a truck.
  94. Hoping
  95. BOP Day @ Atco Raceway NJ on Nov 8th
  96. Blower Motor Cage
  97. Need some help for 3 questions! (Heat Tube, Air Cleaner Hose, Jar...)
  98. Click (or is it Clack) passes away
  99. Old Plates
  100. 69 442/cutlass front windshield pillar interior trim??
  101. Any gourmets out there.
  102. No heat... Getting cold here......
  103. posi unit
  104. Worlds oldest car event.
  105. Noticed this by Chance Tonight
  106. Question about 76 Cutlass Calais
  107. Oldsmobile Service Engine Component Tester
  108. Anyone ever use an Eastwood welder?
  109. Early Cutlass places
  110. Heating a garage with an engine
  111. Blue tooth music through AM radio!
  112. Has anyone ever seen this color combo on a W30?
  113. KB Icon pistons from RPM Machine Inc?
  114. January, 2015 Car Craft Cover
  115. 73 Delta 88 Royale Convert 455
  116. 63 Olds Super 88
  117. R-69 battery
  118. 1972 delta 98 four door
  119. What make and what size carb for 350?
  120. 67 Turnpike Cruiser Conv Ebay
  121. 1972 cutlass...wheel size fitting help...
  122. 1971 W-30 Video
  123. Part Identification
  124. Carb seems to be flooding after a long drive??
  125. 1966 Front Suspension Rebuild
  126. Counting Cars Last Night
  127. Quadrant Madness
  128. wiring harnesses
  129. The Ram Air Myth
  130. Another ebay sale
  131. Information Needed!! 1969 olds cutlass
  132. Junkyard tour
  133. Hot start
  134. 72 cutlass
  135. Please Help!!
  136. Trunkload of cams - what use?
  137. Gear ratio
  138. Baden, Ontario CA
  139. disc brake conversion
  140. 66 cutlass frame
  141. info needed
  142. First "trip" In the Cutlass
  143. 1969 Cutlass Tire Pressure?
  144. ARH Headers - who has them on BBO
  145. 1957 oldsmobil
  146. 1969 Cutlass V8 350 Automatic correct idle?
  147. air compressor questions
  148. camshaft selection
  149. 71 W30 Ebay, How High Will It Go?
  150. How much oil when rebuidling A6 compressor
  151. Buying and selling cylinder heads
  152. 72 Sport Mirrors
  153. +Tool Review - HFT 1/4" swivel Ratchet
  154. Import/Export
  155. In line Fuel Filter Location and Lack of Flow
  156. Who is the member here who.....
  157. mushy brakes
  158. loose turn signal
  159. 1961 Starefire turn signal switch question
  160. Another 1971 Cutlass S
  161. olds 350 help-
  162. service replacement heads ??
  163. Raymond Beadle
  164. The Rectifier 442
  165. 69 Cutlass hood emblem nuts size?
  166. Help please with a 1967 425 ID etc.
  167. Choosing a Carburetor
  168. 69 HO used a dual pattern cam
  169. Who Makes Trim Tags?
  170. Tucker
  171. 71 Cutlass Tail Light Lens
  172. Frustrated delema
  173. oldsmobile ring tone
  174. Does anybody recognize this piece of duct work?
  175. Aftermarket 1970 442 core support
  176. 1965 Cutlass
  177. fuel pump?
  178. Anybody had this problem with Tic Toc Tach from Parts Place
  179. 45 degrees out and starts and run great.
  180. Proliferating Oldsmobiles
  181. Is it from one of us
  182. The car I found but yet do not have
  183. 70 cutlass S w/bench and 4spd 350 rocket factory
  184. 64 Dynamic 88 on Overhaulin
  185. AM Radio Restoration - is it worth it?
  186. Hooker Headers warranty
  187. I'm in a dispute
  188. Atco NJ BOP Show Nov 8 2014
  189. 1969 4-4-2 Rear Bumper Impact Strip
  190. wild about cars
  191. Question: How often does this happen??
  192. Repainting 64-67 442 emblems
  193. 68 Cutlass Roofrail Weatherstrip and Quarter Window Questions
  194. Jerky power steering.
  195. 71,72 cutlass supreme "hip" angular vs round?
  196. There is a couple 442's in here somewhere.
  197. Fuel Tank Issues On My '67
  198. 61 Starfire top switch and backup light question
  199. Will they fit?
  200. Flash back with Year One and Fusick
  201. What do these numbers mean
  202. Any sweet cars for sale out there?
  203. What's it worth...2.41 10 bolt posi rear from 1976 Cutlass?
  204. At Wits End with Dash Electrical Problems 1985 442 HELP!!!
  205. sand blasting or using a flap disk
  206. Poor Judging at Shows
  207. Bucket seat seatbelt oddity ?
  208. Canada
  209. 1970 Oldsmobile Cutlass...option quetions!
  210. EGR connections '73 455 4v
  211. anyone transporting cars from Chicago to Pa?
  212. What would you pay for this holiday coupe?
  213. rear defogger
  214. ----Info on W30 67 442----
  215. No headlights at all when high beams engaged
  216. Wiper Motor Stopped Working
  217. What's special about the holiday hardtop coupe?
  218. Fuel drain back
  219. Good model? 1972 olds cutlass S holiday hardtop coupe
  220. 1965 442 ???
  221. Let's go camping in the Vista Cruiser!!
  222. Any 1968 Convertible owners out there who can comment
  223. Octoberfest pics, Pentwater Mi.
  224. Touching up my Olds Service sign
  225. 2 more yards gone
  226. Quality heater core-69 442
  227. Steele Rubber discount 10%
  228. Cutlass motor swap
  229. Spindle Lock Washer?
  230. Dear Repo Parts Makers - Why Not Make It Right If The Goal Is To Look OE?
  231. September 1988 Oldsmobile radio commercial
  232. New Toy as well
  233. This belong to anyone here?
  234. New Drain plug
  235. my new 1970 cutlass
  236. Toro-powered Fiat
  237. Check out this 98
  238. 327 listing
  239. Dearth of Olds Muscle at Hershey
  240. Cruise season has started :)
  241. Opinions wanted: 1967 Cutlass Supreme
  242. Range of market value on OAI hood and Air Cleaner
  243. two barrel intake
  244. What else do you collect?
  245. No side mirrors on my 55 Olds?
  246. Price check 72 H/O
  247. BOP Show Nov 8 2014 Atco Raceway NJ
  248. Doug's headers - do not fit
  249. 72 cutlass
  250. Removing Plastic inner fender
