Gear ratio
Old Oct 27, 2014 | 07:59 AM
Joeg's Avatar
Gear ratio
Hi olds people! I am wondering, I have a 1970 olds cutlass with the W-31 package. My rear gears are the 3:91's. What would be a good all around gear to put in it so it's more driver friendly on the highway, but I still keep some snap? I can't afford another new tranny for it currently, so a gear swap is what works for me at this time. And of course one that I won't have to put in a new carrier. Some of the research i've done on it says I can only put a 3:08 or 3:42 in there with out having to do some extra work.Thanks everyone.
Old Oct 27, 2014 | 08:02 AM
pogo69's Avatar
morgan
Originally Posted by Joeg
Hi olds people! I am wondering, I have a 1970 olds cutlass with the W-31 package. My rear gears are the 3:91's. What would be a good all around gear to put in it so it's more driver friendly on the highway, but I still keep some snap? I can't afford another new tranny for it currently, so a gear swap is what works for me at this time. Thanks everyone.
i wouldnt go higher than 3.08 and 3.23 will give you decent mileage and not bad rpm on the highway... i like the 3.08
Old Oct 27, 2014 | 08:06 AM
70cutty's Avatar
Beer Connoisseur
I could be wrong but I don't think anybody makes the gears for the O type rear end that's in your car. You can try with Jim, monzaz here on CO, I know he had some that he was selling.
Jim's website
Old Oct 27, 2014 | 08:21 AM
junior supercar's Avatar
your only option without changing carriers is 3.42
I have a buddy with a 70 442 convert with 3.42 and he drives it alot, including the 4 hour trek up to Stanton, MI for the Pure Stock Drags. no issues.
I believe FabCraft in Texas is now making 3.42 and 3.91 Type O gears. There was a thread on here about it. FabCraft is a good place, I've talked with Brad several times.
Old Oct 27, 2014 | 08:42 AM
Ozzie's Avatar
Hollander says that 5.00, 4.66, 4.33, 3.91, and 3.42 were used with the carrier you have; 3.23 & 3.08 used another carrier; and 2.78 & 2.56 was yet another. The axle housing should accept all three carriers. Be very careful if you haven't yet installed a gear set. It's easy to mess up.
Old Oct 27, 2014 | 10:26 AM
rcorrigan5's Avatar
Randy C.
My niece's '68 4-4-2 has the M21 close ratio transmission and she has a 3.42 posi. That works pretty good for "snap", plus the gas mileage is somewhat better. I like that combo.
Randy C.
Old Oct 27, 2014 | 10:31 AM
oldsmobiledave's Avatar
tire height
How tall are your back tires? If you are currently running a 26" tall tire moving to a 28" tall tire will knock about 250 RPM out of the cruise RPM. Might be worth considering prior to swapping gears.
Old Oct 27, 2014 | 11:02 AM
garys 68&72's Avatar
What motor and trans are you running?
Around here, you can typically find good used rear ends cheaper than a gear change. As long as the gears are good, new seals, brake rebuild, and you can have it swapped out in a couple hours. Then sell the old rear.
Old Oct 27, 2014 | 11:15 AM
70cutty's Avatar
Beer Connoisseur
If he is gonna do all that, might as well look for a 71/72 rear end for which the parts are readily available.
Old Oct 27, 2014 | 11:17 AM
really?
So you are telling him to sell off the numbers matching 3.91 rear end from a real W-31....is that your advice?
Old Oct 27, 2014 | 12:34 PM
lol, not exactly....
I didn't see any info on numbers matching, engine, trans etc..
Maybe I should have suggested a chevelle rear?
Old Oct 27, 2014 | 01:47 PM
Me personally, I would keep the rear thats in it and get a bigger gas allowance. The RPMs won't hurt anything.
442 Guatemala
Jan 15, 2010 10:43 AM
squirell
Jul 7, 2009 09:01 AM
Maverick
Drivetrain/Differentials
Feb 23, 2008 02:27 AM
jeffs 89 cutlass salon
Aug 21, 2007 07:57 PM
442 Guatemala
Jun 11, 2007 10:19 AM
