Gear ratio on 67 Cutlass ?
Old Jun 28, 2009 | 06:03 PM
squirell's Avatar
Govt slave
I have a 67 C.S Conv,
330 High comp
2 speed
12 bolt.
What are the standard rear end gears for these cars ?
Old Jun 28, 2009 | 06:33 PM
2blu442's Avatar
With the 2 speed I would guess 2.56, 2.78 or 3.08 Other possible ratios in 1967 could be 3.23, 3.42, 3.55 but with your combination I would expect the taller gears. If it's not been messed with there would be a two letter stamp on the passengerside tube. It could be on the front or the back of the tube. Lots of codes, you may be able to find the list on the wiki site, if not locate yours and post it here. John
Old Jun 29, 2009 | 06:47 AM
67 Cutlass's Avatar
Check out this thread that I posted a picture from my 67 Cutlass manual to better identify the rear end in your car.
Hope this helps.
https://classicoldsmobile.com/forums...t-o-plate.html
Old Jun 30, 2009 | 08:18 AM
squirell's Avatar
Govt slave
Thanx guys,
I'll have to crawl under and see
Old Jun 30, 2009 | 08:36 PM
66400's Avatar
The standard ratio for a 330 2spd auto car should be 3:08. Any other ratio was special ordered.
Henry
Old Jul 1, 2009 | 04:49 AM
wmachine's Avatar
Trying to remember member
Henry
Henry, when you say special ordered, that may be misleading to some.
Many other ratios were simply optional, as also was the "O" rear (12 bolt cover/10 bolt gear). The "P" rear (10 bolt) was standard in '67.
Side note: Supposedly the "B" 10 bolt (with the same gears of a "P") could be there in lieu of the "P" with series 1 and 2 (I believe) carriers. I don't recall seeing one, but most of what I've seen have been the performance rears with series 3 carriers and they were all "P" rears.
Old Jul 1, 2009 | 05:12 AM
88 coupe's Avatar
Junior Member
The term "special ordered" would apply to that 750 HP blown hemi 442 that my uncles brother in law bought new from the dealer. After it out ran everything in the entire western hemisphere, it got stolen and no one ever saw it again.
You probably never heard about it because it wasn't one of your normal options.
Norm
Old Jul 1, 2009 | 05:21 AM
wmachine's Avatar
Norm
Old Jul 1, 2009 | 05:56 AM
Ranzan's Avatar
Getting There
LOL
Old Jul 7, 2009 | 09:01 AM
squirell's Avatar
Govt slave
Henry
Thanx
nj_cutlass72
Nov 20, 2019 09:11 PM
HonestDave
Drivetrain/Differentials
May 30, 2013 12:57 PM
dallasite21
Apr 30, 2013 02:09 PM
442 Guatemala
Jan 15, 2010 10:43 AM
442 Guatemala
Jun 11, 2007 10:19 AM
