Help please with a 1967 425 ID etc.
Old Oct 20, 2014 | 01:52 PM
67cutlass67GS's Avatar
I have heard some good things about the 425. My 330 in my 67 ragtop is tired & I love a BB. The guy selling it says it out of a 1967 Ninety Eight. Engine numbers 389244. He said the head says CFD. Also said he found another number that said 548. I saw the video & it does run. He don't know much about motors or where to locate other ID markings to give me more info. I'm looking for any input at all as this motor is close in location & I'd like it if it's not some boat anchor. Thank you in advance.
Old Oct 20, 2014 | 03:00 PM
If it's the original motor from a 98 it's a high compression 4 barrel motor.
389244D is the casting number for all '66 and '67 425s.
CFD means Central Foundry Division, the place where all GM cast iron parts were made.
The engine number in 1967 was located on a pad on the front of the driver's side head, just under and inboard from the alternator in the photo below:
Here is a guide to the 1967 number codes:
If the car is in fact a '67 98, the code will read Rxxxxxx (with x= any digit).
There is a small chance it could read RxxxxxxS, but that is unlikely.
If the heads have been off, this number could be on the back of the left hand head instead.
Of course, it is always possible that the heads could be from a different engine, but there's no other marking that tells you what kind of engine it is on a non-Toronado.
Last edited by MDchanic; Oct 20, 2014 at 04:25 PM. Reason: Foundry, not Forge - I always do that...
Old Oct 20, 2014 | 03:14 PM
CFD means Central Forge Division, the place where all GM cast iron parts were made.
Thank you Eric, i will call him tomorrow to get the head stamp number.
Old Oct 20, 2014 | 05:09 PM
m371961's Avatar
Naturally, if you can hear it run, ask if you can do a compression check and oil pressure check even if you are planning on a rebuild.
Old Oct 20, 2014 | 07:43 PM
Sounds like a plan. Ill have my son do it as he is up where the motor is. I wont get the motor till Dec.
Old Oct 21, 2014 | 08:07 PM
It does have the R239659S what makes them better or worse ? Thank you
Old Oct 22, 2014 | 03:03 AM
That's the Starfire V8, optional even on the 98, and a step below the Toronado motor.
10.5:1 compression, dual exhausts, 375HP / 470 ft/lbs (vs the Toro at 385/480).
You can't do much better for a stock motor in the Olds world.
Old Oct 22, 2014 | 08:56 AM
R-body_mopar's Avatar
Exclamation
Couldn't agree more, Eric! I had a 1966 425 Starfire.....it was a bear! Hurled that heavy body around like a rocket...only problem now is today's fuel, with that compression.....
Old Oct 22, 2014 | 09:15 AM
Octania's Avatar
R...S
Rocket Science!
One step short of the Toronado 425
a great choice.
Grab it quickly
'548 is the latter half of the heads' casting ID 394549, split with half on each side of the lower center rocker cover bolt
See also the huge "C" on the corner of the heads, near #1 and #8 spark plug
Look for this Toronado engine ID DRILL SPOT which your motor should NOT have:
Old Oct 26, 2014 | 02:27 PM
ok motor was delivered & all is as was stated. Original air cleaner is in great shape. Title from car it came out of as well. 1967 Olds 98, one owner. A guy in Glen Ridge NJ. The car got crushed by a fallen tree. It's all there flywheel etc.i wish I knew how to insert pics in thread.
Old Oct 26, 2014 | 03:23 PM
I want it.
Old Oct 27, 2014 | 04:06 AM
lemoldsnut's Avatar
Very nice. If anyone is looking I have a running 67 toronado 425. Still in the car.
Old Oct 27, 2014 | 07:02 PM
MDchanic the motor is at my sons house. He found these numbers R239659S. Does that help ? Thank you
Old Oct 29, 2014 | 05:55 AM
Oldsmaniac's Avatar
I saw that engine on ebay, looks very correct to me as a 67 Sfire 425. Air cleaner is correct with the longer 4bbl snout on it which was a Sfire only unit. Dual exhaust manifolds etc. It should have a D cast on block just above water pump to the tight of oil fill tube and C letter heads. Hope it works out for you, that is a great engine!
Old Oct 29, 2014 | 07:10 AM
Ya it does have the D at the end of the numbers behind water pump. Yes it was on EBay & amazingly the seller lived about 5 miles from my son. He delivered it free. I didn't take the trans as I was advised it wouldn't work in my Cutlass. He made me a deal for engine only. Super nice guy with some bad *** cars.
Old Oct 29, 2014 | 07:18 AM
Oldsmaniac's Avatar
Well you really should consider a stronger trans to go behind that 425. I am thinking you have the 2 speed Jetaway now which is not a Chevy Powerglide. That 98 trans turbo 400 switch pitch could be made to work with a shorter driveshaft but would be better to get a short tail Turbo 400 like the 442 used as it would make the install much easier.
Old Oct 30, 2014 | 06:21 AM
Ya Oldsmaniac there is no question that the 2 speed junkaway has to go. The short tail TH 400 seems most practical or a very well built TH350. Will the TH400 go in as easy as TH350 ? Im looking for less aggrevation & modification if possible. Thanx
Old Oct 30, 2014 | 06:38 AM
Oldsmaniac's Avatar
Ok let me see if I have this right... The T350 would need a downshift cable hooked to throttle for passing gear. The 400 uses a switch that you already have on your accelerator. I would go with the 400 and not worry about beefing up a trans. Externally they are not much different and install about the same. Yokes are different between the 2. You will want to decide if you want a switch pitch turbo 400 which was the 67 A body trans or the later 68 up non switch pitch trans. The switch pitch requires the appropriate torque converter.
Old Oct 30, 2014 | 06:46 AM
The TH400 will require a shorter driveshaft or having yours shortened, as well as a different yoke.
The TH400 also mounts with the crossmember in the rear set of holes, which will require a new set of emergency brake cables, because the mounting locations will move.
Old Oct 30, 2014 | 06:52 AM
Oldsmaniac's Avatar
If yours is a column shift you may want to look for this dash bezel with the extra S range.
Old Oct 30, 2014 | 08:24 PM
Ok gotcha. The trans is my next hunt. My real fantasy is a 4 speed but I couldn't take the aggravation. Lol
Old Oct 30, 2014 | 08:26 PM
Aaaaahaaa I see u have done this. Lol
Old Oct 30, 2014 | 08:28 PM
Yes it is column shift. So I'll need to find the extra set up. Thank you
Old Oct 30, 2014 | 08:45 PM
Nope. Just try to remember most of what I read and hear, so I make as few of everyone else's mistakes, and as many of my own new ones, as possible.
197064buickspec
Site Help
43
Aug 20, 2014 08:01 AM
Octania
May 5, 2013 08:32 AM
Steve Wike
Mar 11, 2012 11:47 AM
real57vetteguy
Jan 13, 2012 01:03 PM
