mushy brakes
Old Oct 22, 2014 | 07:33 AM
dewcrazzy's Avatar
mushy brakes
I had a bad front passenger wheel cylinder so I changed it the other night. I bled the brakes twice and now the pedal is soft and travels far plus hard to stop and the brake light will come on. I added a power booster a couple years back. the mc and booster are almost new. it's a 4 wheel drum system. the same day I did the cylinder my stock carb was performing bad. my brother let me use his extra holley spread boar that is like a stock carb 650 cfm. the brake booster vac is hooked to a port behind the carb, should it be plugged into the back of the holley?
Old Oct 22, 2014 | 08:00 AM
The brake booster needs to be hooked to a full vacuum port on the carb. When you changed the wheel cylinder did you readjust your brakes?
Old Oct 22, 2014 | 01:38 PM
dewcrazzy's Avatar
I gravity bled the brakes and everything is in great working order. Thanks
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
Gtimmons
Cars Wanted
Sep 30, 2006 06:34 PM
Supreme
Aug 11, 2004 06:58 PM
