PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Carburetor question
  2. 1980 lemans
  3. Looking for some owner info on '64 Cutlass Convert
  4. Stone Guard/Grill Gap Adjustment
  5. Carshow at Don Garlits Museum in Ocala,FL
  6. a couple 63 88 questions
  7. anyone have experience with metal flangers?
  8. Date Code Timelines
  9. Help Pulling Motor and Trans
  10. Quadrajet Date Code VS Production Date
  11. Underhood and trunk light
  12. Looking for Minnesota Members
  13. Waterless coolant
  14. Killer 'vette Goes to Auction LQQK!
  15. re impala parts inter change wirh olds
  16. Help needed in TN
  17. Banish these *bleeping* Banshees!
  18. Fuel Line 63 Olds Starfire
  19. 65 impala parts
  20. 1961 88 steering gear questions
  21. removing old wax
  22. VIN Location
  23. what shifters will work with the stock console
  24. Birth Certificate?
  25. Chrome Polish Samples at 2013 Nationals
  26. In search of my dads 442
  27. Drug another one home, 1964 F85 wagon
  28. Pre-Purchase Inspection
  29. Anyone have advice on cleaning conv. top?
  30. 67 W30 air cleaner
  31. mounting bracket problems?
  32. to Stripe or not to Stripe
  33. 70-442 Engine oil fill decal question
  34. Mirror Question
  35. Micky Thompson Valve Covers
  36. 1970 442 - Should I buy?
  37. AED Performance Carbs Recommendation
  38. 1964 Oldsmobile Body Tag
  39. c/r dilema
  40. Power steering help needed!
  41. 53 rocket 88 radiator
  42. What do you think it is worth??
  43. Brake booster leaking vacuum?
  44. Question Ref Gauges
  45. Bucket seats
  46. 62 starfire . Questions.
  47. Anybody near Reno or Winnemucca Nevada? It would be a shame to smash these cars!!!
  48. muncie trans decoding question
  49. Velocity channel
  50. Hood hinges
  51. Big dollars for original 70 W30 4spd convert
  52. And then there was two...
  53. Arizona Olds Show
  54. Overhaulin Season 8 Episode 1........Olds 442
  55. Need a little help
  56. 1972 cutlass louvers (rear)
  57. Lifting Body from Frame
  58. Assembly manual pages needed
  59. Finally got the cutlass out of storage
  60. Central Texas... this Saturday!
  61. Heater control valve
  62. 1970 442 i need info
  63. Anybody ever front clip a '61 88?
  64. Distributor tuning
  65. Working on other brand with a friend...
  66. Another Cutlass? Yes!!
  67. Oldsmobile letters /fonts question
  68. I picked up some more cars
  69. 67 F85 floor pans
  70. What is my 1970 olds 442 matching number Muncie 455 conv worth?
  71. hub assy
  72. Good Guys Dallas
  73. Good guy
  74. 71 442 Fuel Tank And Fuel Line Replacement Quiestions
  75. My 1969 442 value?
  76. Great Family here
  77. Sparky's Carburetor Service - OUTSTANDING
  78. Oversize?
  79. Master Cylinder
  80. Is mine worth this much???
  81. My rebuilt harmonic balancer is no good.
  82. 79 H/O worth anything to anyone?
  83. 56 Olds Super 88 choke.
  84. Drums to disc
  85. '68 Toronado and the 2013 Great Race - Part 1
  86. Connecting rod caps...
  87. Original Radiator? Please Help
  88. Spead the word
  89. What is a good additive for ethanol
  90. Camshaft identification ?
  91. 69 442 help
  92. Seventies W-30 Fuel Pumps
  93. A diamond in the rough at the Cleveland Auto Show!
  94. 65 442 Post Window Trim
  95. Old Delco-Remy parts, I like em..
  96. 1967 cowl tag help
  97. I need measurements of the '70 HDG Top Plate
  98. Pertronix Ignitor 1181 vs. 1181LS?
  99. '61 olds 88 chassis part numbers?
  100. seat belt holders
  101. more 61 olds 88 questions
  102. How much is gas where you live?
  103. trying to see if I can find my old 442
  104. Question about car for sale
  105. Decipher my cowl tag!
  106. Updating '66 or '67 Cutlass gauge set
  107. 67 Delta 88
  108. 394- Will the LH exhaust manifold bolt on the RH head?
  109. Bulb Model for Dash Gauges?
  110. 1962 starfire vacum lines
  111. Question on title numbers
  112. Trim tag code help!
  113. is a stock '67 olds 442 "P" type rearend exactly the same diff used on '66 '67 GTO's?
  114. Yearone Discount Code
  115. Alarm system
  116. 9th Annual Spring BOPC show, May 17, Media, PA
  117. Air Compressor ??
  118. keeping cool
  119. cool vintage coil spring lift kit
  120. #7A heads vs #5 heads
  121. Oai screen installation
  122. Another Toyota Accelerates and Crashes!
  123. 1961 olds super 88 questions 394
  124. 70-72 shifter cable holes in floor pan?
  125. Dash pot
  126. Burnet, Texas Friday nite show...
  127. 70 w30 hardwear colors???
  128. 2 x 1970 W30 4 speed vert's documented!
  129. oldsmobiledave feedback
  130. 55' four barrel rebuild help
  131. Attn Oldsmobile Streetrockets of Detroit
  132. Spark Plugs
  133. Throttle Cable Adjustments.....
  134. Help with getting a new title
  135. 1976-1977 olds cutlass
  136. My Fathers Oldsmobile
  137. Best Decals?
  138. Project Ideas
  139. Ebay concluded auctions
  140. Big book binding
  141. Anyone in DFW Gonna Be at The Goodguys Lonestar Nationals March 14-15-16 @ TMS?
  142. Rotunda Diagnostic machine
  143. Tracking down original owners
  144. Central Texas... this Friday nite cruise in
  145. Another timing question ???
  146. Trunk Picture
  147. 66 442 Power Steering Pump Rebuild
  148. Need Help!
  149. License Plate Resto
  150. I Wonder If the Top Goes Down?
  151. Old car and truck pictures
  152. Do Cutlass' Start in 9F? Hell ya they do
  153. Lansing's 1967 snowstorm
  154. Which part is correct for a 1967 Toronado?
  155. '67-'69 & 1970 Stock Disc Brake Proportioning aka (Metering Valve) Seal Rebuild Kits
  156. Muscle Car and Corvette Nationals aka MCACN 2014
  157. 48-53 Olds medallion
  158. Does anyone go to this car part fleamarket in MD?
  159. .001 main bearings
  160. Fan Clutch
  161. fuel pump?
  162. Then and now pics
  163. Pictures from Blackhawk
  164. 4 amp blows as soon as its inserted?
  165. name that power brake booster...
  166. Wipers won't go down all the way. 71 Cutlass
  167. Starter date?
  168. OPGI Sheet metal sale exclusions are sheetmetal
  169. 67 442 original disc brakes ( Value)
  170. Need help from someone willing to do some jail time
  171. Anyone Near Plymouth MI?
  172. Thinking of doing carb rebuild.
  173. 98 with dual carbs
  174. oldsmobile and bopc at 41 in september 2014 sing up listing.
  175. 1967 Cutlass upper garnish molding question
  176. 66/67 Rally Pac
  177. Peek at my 69 Vert Project
  178. New member
  179. 1990 vs 2014
  180. Pulley Identification
  181. How do you attach the quarter window chrome weatherstrip channel?
  182. Door Edge Guards
  183. New cam old question
  184. 1962 Jetfire brought back to life
  185. If I could have a do over......
  186. Odd harmonic balancer / dampener
  187. Nice day for a short cruise..
  188. Heavy Hearted Tonight
  189. 66 tri carb
  190. And they dont repop these why???
  191. Hurst Dual Gate
  192. 394 intake manifold question / poor compression
  193. Need help to remove rocker panel clips...
  194. 12 bolt rear end locks up in reverse
  195. 7040253 Carb
  196. S71 completion video (Turbo 1971 Cutlass)
  197. Out of state sales help please !!
  198. Cottonwood Az area
  199. Shorty Header fittments
  200. ree dying breed part 2
  201. is it true these cars are part of a dying breed
  202. See the for sale section for wiper motor decal info
  203. Air conditioning controls and vacuum
  204. 1970 Black on Black W-31 4 speed, Documented
  205. Do you know this red '54 convertible? (If not, maybe a similar car?)
  206. white wall cracking
  207. Question about the series number referenced in the service manuals
  208. Wiring connectors & parts wanted
  209. Anyone own this ride??
  210. 1966 Cutlass 330 OEM throttle linkage options
  211. Wiper motor decal sample picture
  212. Window Stickers
  213. I'm going into withdrawl
  214. Olds 455 Build
  215. BPOC swap meet in St Charles, IL last Sunday?
  216. Coil on manifold
  217. cutlass wheel code
  218. Airtex mechanical fuel pump part number 40704
  219. Heater A/C control valve vacuum switches and part numbers
  220. Car resto shows
  221. Just got a call from the wife...not good
  222. Suggestion on speed nuts for trim
  223. 1969 Cutlass Center Console
  224. Strap bolting question
  225. So I think I like these cars, new car thread
  226. 69 442 Console Help
  227. what size tranny
  228. Bad Day at the Garage Today
  229. Dumb question on Comp Cam 1441 Rocker kit
  230. 1967 330 4bbl Carb Linkage Pic Needed
  231. 73-77 olds site ?
  232. 71s goes up in smoke
  233. 1966 Olds 442 3speed Questions
  234. It's going to live just a little longer.
  235. header tube size
  236. interior light door switch Olds Starfire
  237. Seafoam, to use or not?
  238. Quadrajet Carb filters/inlets
  239. Raising Compression one point or so.
  240. AC Ports Oldsmobile 1964 98
  241. Replacement radio for Cutlass 442
  242. Batmobile based upon an Oldsmobile
  243. gear position indicator 72 cutlass
  244. Face book?
  245. can you run straight pipe
  246. Wiper motor part # decals
  247. 1970 442 help me please
  248. Warehouse fire destroyed my 1967 Cutlass
  249. Has anyone else seen this?
  250. 330 or 394
