Alarm system
Old Mar 9, 2014 | 10:31 AM
pav8427's Avatar
Alarm system
I am thinking my 79 H/O has a alarm system installed.
There doesnt seem to be any add on wires anywhere.
I need to eliminate it as a reason why it is not starting.
Anyone happen to know where I should start looking?
Thanks, Doug
Old Mar 9, 2014 | 12:02 PM
Lady72nRob71's Avatar
So you confirmed you are not getting a spark or is the starter motor not even activating?
Old Mar 10, 2014 | 02:45 PM
pav8427's Avatar
Looked it over last fall before I put it away for the winter.
No spark then, figured it needed a module.
Installed new ac delco module.
Just put in a new coil.
Still no spark.
Turns over nice and strong. HEI looks new inside.
Full power to dist.
Old Mar 10, 2014 | 02:54 PM
If you have full power to the distributor then there is nothing else in line, it's in your distributor. Just for grins, run a jumper from your battery to the distributor and see if it starts. Disconnect the tach if it has one for now also.
Old Mar 10, 2014 | 03:26 PM
You changed the module, but not the pickup (or the pickup wires).
Check those out.
Old Mar 10, 2014 | 03:47 PM
pav8427's Avatar
Pickup is the next on the list. This looks like a fairly new Dist.
It ran when parked, but that was 10 yrs ago.
I will try the jumper.
Old Mar 10, 2014 | 04:06 PM
Originally Posted by pav8427
It ran when parked...
Yeah, but so did this:
Old Mar 10, 2014 | 04:20 PM
That ought to buff out. Fresh tuneup, air them tires, flush the tank, good as new.
Rattlecan
Aug 17, 2018 04:07 PM
hurstman1972
Hurst/Olds
Sep 17, 2012 09:30 PM
CutlassLegend
Aug 12, 2011 06:46 AM
Jamesbo
Aug 20, 2010 07:36 PM
kvenza
Jan 6, 2008 05:49 AM
