Alarm system
Old March 9th, 2014, 10:31 AM
pav8427's Avatar
Alarm system
I am thinking my 79 H/O has a alarm system installed.
There doesnt seem to be any add on wires anywhere.
I need to eliminate it as a reason why it is not starting.
Anyone happen to know where I should start looking?
Thanks, Doug
pav8427 is offline
Old March 9th, 2014, 12:02 PM
Lady72nRob71's Avatar
So you confirmed you are not getting a spark or is the starter motor not even activating?
Lady72nRob71 is offline
Old March 10th, 2014, 02:45 PM
pav8427's Avatar
Looked it over last fall before I put it away for the winter.
No spark then, figured it needed a module.
Installed new ac delco module.
Just put in a new coil.
Still no spark.
Turns over nice and strong. HEI looks new inside.
Full power to dist.
pav8427 is offline
Old March 10th, 2014, 02:54 PM
If you have full power to the distributor then there is nothing else in line, it's in your distributor. Just for grins, run a jumper from your battery to the distributor and see if it starts. Disconnect the tach if it has one for now also.
oldcutlass is online now
Old March 10th, 2014, 03:26 PM
You changed the module, but not the pickup (or the pickup wires).
Check those out.
MDchanic is offline
Old March 10th, 2014, 03:47 PM
pav8427's Avatar
Pickup is the next on the list. This looks like a fairly new Dist.
It ran when parked, but that was 10 yrs ago.
I will try the jumper.
pav8427 is offline
Old March 10th, 2014, 04:06 PM
Originally Posted by pav8427
It ran when parked...
Yeah, but so did this:
MDchanic is offline
Old March 10th, 2014, 04:20 PM
That ought to buff out. Fresh tuneup, air them tires, flush the tank, good as new.
Rattlecan
August 17th, 2018 04:07 PM
hurstman1972
Hurst/Olds
September 17th, 2012 09:30 PM
CutlassLegend
August 12th, 2011 06:46 AM
Jamesbo
August 20th, 2010 07:36 PM
kvenza
January 6th, 2008 05:49 AM
Quick Reply: Alarm system
