Alarm system
Alarm system
I am thinking my 79 H/O has a alarm system installed.
There doesnt seem to be any add on wires anywhere.
I need to eliminate it as a reason why it is not starting.
Anyone happen to know where I should start looking?
Thanks, Doug
Thanks, Doug
Looked it over last fall before I put it away for the winter.
No spark then, figured it needed a module.
Installed new ac delco module.
Just put in a new coil.
Still no spark.
Turns over nice and strong. HEI looks new inside.
Full power to dist.
Still no spark.
Full power to dist.
If you have full power to the distributor then there is nothing else in line, it's in your distributor. Just for grins, run a jumper from your battery to the distributor and see if it starts. Disconnect the tach if it has one for now also.
Fresh tuneup, air them tires, flush the tank, good as new.
