67 442 original disc brakes ( Value)
Old Mar 2, 2014 | 07:07 AM
olds3442's Avatar
I wanted to know what a 67 original disc brake set up is worth, complete rebuildable , thanks John
Old Mar 2, 2014 | 08:25 AM
The big differences from the more common 1969-72 brakes are the four piston calipers, unique caliper mounting brackets and backing plates, and the two-piece rotors. All of these parts are now being repro'd, since they also fit Camaros. You might want to research the prices of the repro parts as a benchmark. As an example, the four piston calipers run about ten times what the single piston calipers sell for ($200 each vs. $20 each). Repro caliper brackets run about $135 a set vs. about $50 a set for the single piston brackets.
Old Mar 2, 2014 | 08:26 AM
66400's Avatar
If someone wanted a dual piston setup it should bring 300-400.
I had a set for sale for several years and no one wanted them. I finally sold them for 150.00 and it was healthy rotors and clean no rust or pits Texas parts.
You may have better luck than I did!
Henry
Old Mar 2, 2014 | 09:59 AM
I'm restoring my 67 to what I'd call ultimate stock, with every option I can find, but the discs I'm putting on it are the later ones. I suppose I'd be tempted by a complete correct 67 set, but I just know from seeing Corvette brakes how much of a pain they are.
Old Mar 2, 2014 | 12:11 PM
steverw's Avatar
Actually after I bought stainless sleeved calipers for my vette 9 years ago they have not leaked a drop and work flawlessly. I talked to Muskegon Brake about my 67 Olds calipers they will rebuild and stainless sleeve them for around 200 each if I remember correctly. I do plan on doing that in the future.
joeculhane
Brakes/Hydraulic Systems
Sep 1, 2014 04:46 PM
Napoleon Solo
Apr 24, 2013 11:02 AM
62radarlove
Feb 23, 2012 05:35 PM
buddys442
Oct 19, 2011 04:19 PM
rockethound
Feb 13, 2010 10:22 AM
