Throttle Cable Adjustments.....
Old Mar 7, 2014 | 05:59 AM
tds's Avatar
tds
Hello,
Is there any way to adjust the throttle cable on a 1967 Toronado? Need to make it about 1/2 longer. The way it is now when I push the gas pedal to the floor, the cable slips through the plastic gromet, and the car just idles. If the cable was 1/2 inch longer, that would not happen......Any thoughts?
Thanks,
Tom
Old Mar 7, 2014 | 06:56 AM
2blu442's Avatar
Hi Tom
I'm not picturing the grommet where its slipping. Can you post a picture? If not, describe exactly where the grommet is? John
Old Mar 7, 2014 | 12:03 PM
tds's Avatar
tds
John,
It is the grommet that fits inside the little round hole at the top of the gas pedal linkage inside the car. It is what holds the throttle cable. When I push the gas pedal to the floor, the throttle cable is not long enough, and it justs goes through the little plastic grommet that is supposed to hold/stop the cable. Clear as Mud? I'll try to take a pic this evening.....
Thanks,
Tom
Old Mar 10, 2014 | 05:07 PM
2blu442's Avatar
Hi Tom
Here's some pictures of the throttle pedal and parts inside the car. Do you think if you replaced the plastic grommet that would fix your problem? John
Old Mar 11, 2014 | 06:44 AM
tds's Avatar
tds
Thanks for posting the pics. That is exactly where the problem is! When I floor the gas pedal, the cable goes right through the plastic grommet. I've replaced the plastic grommet, but it did it again. The cable is not long enough to allow the gas pedal to go to the floor. When I do push the gas pedal to the floor, it pulls the cable through the grommet. Any ideas?
Thanks for your time!
Tom
defiant1
Feb 4, 2020 08:53 PM
1973olds98
Nov 24, 2010 02:19 AM
Ausraven
Nov 2, 2010 08:57 PM
nelsontj
Mar 4, 2009 03:33 PM
aristellier
Oct 4, 2006 04:50 AM
