New cam old question
Have a Lunati going into a 455. Rebuilt E heads. Specs: Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,300-5,500
Intake Duration at 050 inch Lift:219
Exhaust Duration at 050 inch Lift:227
Duration at 050 inch Lift:219 int./227 exh.
Advertised Intake Duration:262
Advertised Exhaust Duration:268
Advertised Duration:262 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.510 in.
Valve Lift with Factory Rocker Arm Ratio:0.499 int./0.510 exh.
Lobe Separation (degrees):112 Will this work w/stock rockers, pushrods,ect? Thank-you.
Thank you for reply. Rebuilt heads include the new springs. No milling/decking. Information like this is very hard to find on the 'net. A reference library of builds from bare bone (mine) all the way to beyond insane would be great. Combinations and updated parts dealers. Mondello (what 2 of them?) have Helter Skelter reps.
1979403ta
June 28th, 2011 07:00 PM
