Stock Cam verses Efficiency Cam?
If you were going to rebuild a small block Olds for daily use, what cam would you run? OE or something else?
87 Cutlass with 2:56 gears.... TH 350 trans...
It depends on what your trying to accomplish and the rest of the parts used in your rebuild. Are you rebuilding the engine back to stock or going for performance? Those gears won't work for a performance build.
Stock. 8.0-1 compression daily driver - fuel economy, if there is such a thing... I already have a performance minded 455 car, this will likely be a freshened up 403 replacing a 307, so the 2:56's will likely stay, the 403 torque might help it in part throttle cruise situations.
Yeah, lots of them.
The Performer cam is 204º @ .050" lift and 280º advertised duration. Compare to a Crane Cam that has the same 204º @ .050 but its advertised duration is 260º.
http://crane.carshopinc.com/product_...d/16380/803902
fastolds
October 10th, 2016 05:32 AM
odddoylerules
24
January 22nd, 2014 06:35 AM
Dan Wirth
September 1st, 2009 07:13 PM
