Carburetor question
Old Mar 23, 2014 | 08:15 AM
jmills's Avatar
Carburetor question
I have a 1952 Olds., 303 Engine with Rochester 4 barrel carburetor. With the current adjustment, there's a "loping" sound when the car is running. What is the "proper" adjustment for this carburetor?
Old Mar 23, 2014 | 08:26 AM
hook up a vacuum gauge to manifold vacuum and adjust for the highest attained vacuum on the gauge. Both A/F mixture screws should be adjusted so that they are about equal turns out from their respective bottomed out positions.
Old Mar 23, 2014 | 09:48 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Probably a good rule of thumb is turn them until they stop while being careful to not over tighten them. Back them out about 2 turn and them follow the procedure Eric detailed above. It may be possible there could be something else causing your problem. A vacuum gauge is a great tuning tool on these old cars. You may want to tweak your timing using the vacuum gauge too. You should be running at least 15 inches of vacuum if you engine is in fairly decent shape.
Old Mar 23, 2014 | 01:34 PM
jmills's Avatar
Thanks' guys!!! I'll give it a try!
Jerry
AirborneRME
Jul 10, 2013 01:08 PM
Playerdark
Jan 25, 2013 02:19 PM
1971CutlassSupreme
Jul 5, 2011 04:20 PM
yeahbuddy
Jun 1, 2010 05:38 AM
ViceGuy
Mar 25, 2007 01:43 PM
