Need Rochester Carburetor Help
Old Mar 25, 2007 | 01:32 PM
ViceGuy's Avatar
Greetings: Does someone know how to determine the CFM of a stock Quadrajet on a 1970 Cutlass with the Rocket 350? I found some numbers on the carb, but not too sure what they mean. Any help would be greatly appreciated. And while I'm here, could someone tell me the max CFM I should be looking at with the 350 engine. Thanks in advance....
Old Mar 25, 2007 | 01:39 PM
70Wcars's Avatar
Q-jet were only made in 750 and 800 CFM...your 70 Olds will be a 750, but few flow that as delivered from the factory. Hope this helps.
Old Mar 25, 2007 | 01:43 PM
ViceGuy's Avatar
Thanks Dan.... I'm looking to replace it with another Quadrajet and found one that has been rebuilt / tested. That one was is a 750. Wanted to make sure that I would be replacing it with a correct one. Thanks again.........
63super88
Sep 17, 2019 01:48 PM
oldsman7
Jun 13, 2011 10:33 AM
1965zoso
May 23, 2011 06:33 PM
67442nut
Aug 31, 2010 11:31 AM
