View Full Version : General Discussion
- Cool early 70's drag race video
- divorced choke manifold, stove choke carburetor...what to do?
- Disc Brake Kit Vendor
- Worn Down Ignition Key - 1970 GM Key Code
- Lock Linkage Rod
- Looking for a 1971 442 w-30 I owned
- Requesting your .02 | 71 Upgrade Planning
- electric fuel pump
- Miss Belvedere
- need help 8 track wire
- Who carries parts for Oldsmobile cars?/
- OLDS Photos from GNRS in Pomona CA
- Services needed.......
- 70 sx w32? worth anything or continue my drag project?
- 1970 cutlass glove box liner
- Is there a A/C system for a 330 engine??
- Windshield Washer Pump Replacement 72 CS
- National seal lookup
- What's a Good Car Cover for a Wagon
- Got my records today
- 1966 442 Cowl Tag
- 1970 OG transmission
- Gnrs 2018
- Gen II Custom Cruiser wagon with ELECTRIC brake booster.
- Any photos of 1969 Oldsmobile in NASCAR?
- Vintage Rallye 350 Pics
- Vacuum reservoir
- Does Anyone Know Blue Dash Color Codes for 1972 Cutlass/ Vista Cruiser, etc?
- New gas tank and pickup
- 62 starfire 394ci
- Educate me!!! New owner or 1970 vin 336770z112878
- Glass Guys: Scratched Windshield fix?
- Thank You CO
- Which mufflers would you go with?
- "Full size" glove box light into Cutlass - quick how to
- 1967 Cutlass AM FM Radio Service
- 68 400 block 38m149212 free if it matches your vin
- Barrett-Jackson an observation
- 71 sports coupe questions
- Should my Tailgate Vista Cruiser Emblem Stand Out like this?
- 1969 f85 w-31
- Hot olds
- Free 68 Protecto Plate Booklet if it matches your Car
- Body tag (cowl)
- 66 l69
- 1970 front windshield
- 68-69 Wing window
- I have noticed several cars during this auction season that are painted underneath
- supplemental restraint system bags
- Wild Oldsmobile in Enterprise Commercial
- Aftermarket HEI coil lead colour?
- Polyurethane control arm bushings
- Cruise Control bellows end plate ID??
- Englishtown to end drag racing
- Remedy for bolt that won't catch threads
- Am I misssing a Splash Shield Inside my fender?
- Paint code question
- Looking to buy a 1968 442
- RIP Dan Gurney
- 1968 "W-30" in Feb 2018 Hemmings
- Scrounging at the junkyard!
- 63 Olds 98
- Bypass Hose
- Seized brake reservoir cap
- '65 f85 fuel tank spews back
- Aftermarket J2 air filter housing ID
- Can Anyone Take a Picture of their Olds Wagon Tailgate?
- What kind of car did my engine come from?
- Dealer zone codes
- The Governor's Olds
- Found: '70 Olds warranty cards w/VIN...yours?
- R71S Repro Battery where to buy???
- QJet electric choke
- Restoring rear view mirror - a "how to" for the DIYer
- Pearsonville, California junkyard
- Drag racing in the good old days
- Car covers
- Aluminum heads for a 68 350 Cutlass
- Anybody for Hire near OKC for inspection???
- Conventional vs synthetic fluids
- Reproduction W27 Cover
- 67 4-4-2 with Hurst Dual Gate
- The NB Center for American Automotive Heritage (Video)
- Oldsmobile experimental manifolds
- Craigslist unrestored 72 H/O in York pa
- 1968 442 Vaccum canister for trunk release
- Four Door hard top doors on a flat top wagon ?
- HighPerfromanceOlds.com
- Wheel dollies
- Steering box I.D. and rebuild info
- 389244d
- 62' front upper control arms caster mod
- NOS GM thermometer
- olds powered hauler
- Memories of Olds gone by...
- Can anyone recommend buying this Cutlass Front Center Stone Shield Panel?
- Mecum experience anyone?
- '70 CS convert. vin
- Did I put together the tailgate window regulator gears right?
- I wonder if anyone will save one of these old Grande models?
- Header help
- Rear control arms
- 1985 Toro seat
- 1967 Olds Power Antenna Relay ?
- Control arm bushings
- Vinyl top color .... opinions?
- LED Signal Light Bulbs
- What am I looking at
- Ethical services question
- Hood help please
- cloned tpms sensors
- Classic Exhaust Inc: normal, turbo, or glasspacks?
- gassers
- 25th show of the Northern Lights Olds Club 2018
- Aftermarket AC identification
- 1967 442 convertible track pac?
- Engine/4speed trans for a 65 delta 88
- Please help me!!!!!!!!
- 1970 442 replacing woodgrain on dash
- The Parts Place 10% off through 1/1/18
- '68 442/Cutlass fender peak moldings
- Who was asking me about an 890 open faced alternator?
- Restore 68 Hood Vents/Inserts?
- Correct 68 Fender Braces?
- Hardtop Roof Panel Emblem
- build date
- OAI Hood Twist Knob Installation
- Exhaust system options off manifolds 1970 442
- 66 fender ornament
- New Years Top
- 1970 F85 Rallye 350
- 1965 Olds Cutlass History search
- Olds vs. the world
- Take it apart, and 5 years later can't remember... - 68 Cutlass Q's
- 1964 442
- Cutlassfi Mahle coated 400 E pistons
- Bambi again
- App. build date of 67 442
- Most desirable??
- Merry Christmas and Happy Holidays
- Anybody else done a chassis swap?
- Differences in models
- B Body Posi Carrier ID
- Glasstek OAI Hood Question
- 1970 pass right mirror
- Looking at a 442?
- Vin and motor number help please
- Starter/alternator/water pump #'s
- Parking brake cable
- 1969 Hurst Olds nos OAI foam seal
- 69 intake
- 1 ashtray in a 56 super 88
- Indianapolis World of Wheels Motorama, Feb 9-11
- Rear Bumper Jacks
- W-35 spoiler
- Radio query/1973 '88
- Shaved door handles
- Console brackets
- Keep your GM decal
- 1972 Cutlass Supreme convertible w/455 production numbers
- 1991 Quad 442 on Ebay
- Cutlass Build Date.
- R E Olds Transportation Museum raffle car
- Anybody know this W??
- The last Oldsmobile heads to auction (Dec15)
- Is it RARE ?
- 1970 442 cowl screen
- 1970 455 Crankshaft Cracks
- Should I use a battery warmer or trickle charger?
- '70 Tooth Rubber Nubs & Gasket?
- Timing settings
- 1950 Olds 88 DeLuxe Club Sedan article
- 1970 w30 gold stripe color-23197- G H
- 70 post door
- 70 w 30
- Newbie seeking guidance/knowledge/assistance
- Quietest mufflers possible? 2.5 inch pipes.
- 64-69 4 speed console top plate From the parts place anyone try yet
- car accident advice
- Car Transportation Needed - Pennsylvania to Chicago
- Anyone Know This F-85 W-31
- Kmart lifetime battery
- Storing a car under a Two post lift
- Mirrors
- 1950 vintage olds racecar
- Introduction dates w30/31
- Hurst Old pics- a huge Olds collector in Canada?
- Buyers scam?
- More NOS Alternator + Pulley Pics + Info
- 68 Cutlass Trim Info
- Can't start my car in rare cold weather
- My Dream Car
- Pre bent steel brake lines
- Should the Door Loks Stay in the Doors for repaint? (1972 VC)
- Correct casting color ?
- radiator replacement
- Oldsmobile W-31 Invitational Showcase 2018 MCACN
- Shipping Nightmare
- Estate sale heads
- Wheel bolt pattern on B and D cars?
- Body tag "Z" ?
- To restore Vista Cruiser?
- Happy 100th anniversary, Finland!
- Added dual A/F ratio sensors & meter today
- Foward harness.
- OAI scoops?
- Tach I.D. ?
- SW Michigan in December had the Olds out twice anyone else?
- MCACN X 2018, Tenth Anniversary Event
- Whats This, Anyway??
- 1970 Delta 88 disc brake pad installation
- Free Broadcast card for 1969 Cutlass 2 Door Hardtop
- Installing hood pins
- Cutlass Carpet Sound Deadener / Underlayment?
- Anyone Else Get Nervous?
- Build lists?
- "street out laws"
- 85 Toro power seat coupling replacement
- column shifter question
- Always check new parts
- Steering Wheel Restoration
- 1970 olds 350 engine
- Brake Booster Rebuild / Replate
- Type of Air cleaner
- PhoenixGraphics Technical Decal Kit a joke
- Parts required and part numbers?
- Clutch question
- Oldsmobile Toronado?
- Smaller Dr. Oldsmobile decal?
- WIW 455 Olds and Tranny
- Best possible oil change and tune up
- I hate rodents!!!
- Mc&cn 2017 barn finds w31
- Holley 625 cfm street demon
- scrappie.... Turn on contact
- How to tune Qjet with a vacuum gauge
- Msd EFI
- Trunk Spatter Paint and Hardware
- Framingham License Plate
- Radiator for 65 Cutlass (non-A/C)
- Carb help
- 1970 w-30 stripes
- Realistic value 1972 cutlass convertible
- Rpo p62?
- 1970 Cutlass Supreme hood tongue/bumper fitment
- 88's from the 90's. No love?
- Engine I.D. stamping
- Cold Start Issues
- Lots of road noise thru trunk
- Anyone with experience on the Panther body cars?
