Did I put together the tailgate window regulator gears right?
Old Jan 6, 2018 | 12:17 AM
tcolt's Avatar
When I took the assembly out of my Vista to clean and lube it the gears disengaged from each because of the spring action. I tried to figure out exactly how they go together again, but wanted to see if anyone else had experience with this? I'm pretty sure that the left and right hand plastic rollers should be at roughly the same height when the assembly is horizontal, but that isn't easy to see accurately, so I engaged the gears so that the first tooth on the left hand gear in the upper left corner of the picture engages with the first tooth on the right hand gear in the upper right corner of the picture. That seems to make sense, but it doesn't really make sense that there is much more gear left on the right gear that would never engage with any opposite teeth (bottom center of the picture...). Am I over-thinking this?
Thanks, Tom
Old Jan 6, 2018 | 12:32 PM
Yellowstatue's Avatar
Look at the wear pattern on the teeth to see if there is a clue as to the original fitment.
Old Jan 6, 2018 | 01:10 PM
tcolt's Avatar
Thanks. I checked, but it's hard to really see any wear pattern.
Old Jan 8, 2018 | 08:31 PM
nsnarsk65cutlass's Avatar
You need to match the lines on both sides to the lines on the center bracket.
Old Jan 8, 2018 | 11:11 PM
tcolt's Avatar
Wow. That makes sense. Thank you! I would have had it wrong and I'm glad I didn't install that whole assembly back into the tail gate with the gears wrong :-)
It's still weird that the gears don't have the same number of teeth on both sides. The only thing I can think of is that they are used for different applications?....
The only problem is I'm not sure how the lines line up. There are two lines (one long and one short) on the right hand side gear. Those could line up with the equal length marks on the center bracket. But which line do I use to line up with the single mark on the left side of the bracket? The longest line in the center of the three lines on the left hand gear?...
Old Jan 18, 2018 | 11:16 PM
tcolt's Avatar
Did I get the right way to mesh the gears now?...
Old Jan 19, 2018 | 09:06 PM
Looks good to me.
Old Jan 19, 2018 | 09:35 PM
tcolt's Avatar
Ok. Thanks man. I still have no idea why one hear would have more teeth on either end since they'd never engage with anything anyway, but I should be back in business. It'll be nice to get car parts back out of my living room and onto the car :-)
BGVISTACRUISER
Oct 4, 2018 08:17 PM
redmule
Jan 18, 2016 11:29 AM
63super88
Aug 18, 2014 01:17 AM
197064buickspec
Sep 9, 2013 08:55 PM
nonhog
May 6, 2011 04:01 AM
