Always check new parts
Just venting here.
The poor quality of hydraulic lifters is well known, but I am continually surprised. A set from Howards had two lifters frozen up. I didn't bother looking any closer.
A set from Crower though....
They apparently didn't deburr the inside of the lifter after drilling the oil hole. Those shards flaked right off with a little poke from a screw driver. Just waiting to pop loose and really mess something up. About 12 of the lifters were like this.
At least only one had this extra machining done on it
*sigh*
*sigh*
Oddball, thanks for posting. I would never think stuff like that makes it out the door of a reputable manufacturer. The sad part is you would never suspect the lifter metal shavings if it wiped out a bearing or cam lobe. I hope word of mouth spreads fast to the manufacturer. Thanks again.
I know roller adds a pile of money to the price of a rebuild but this is why I use roller now. So many horror stories about flat tappets these days. My problem now is, you can't go roller on my old Jetfire engines.
Just thinking out loud, if quality of something is on that level, is the quality control any better on roller parts? Just wondering, bad roller gone through quality control = way more problems.. Way more things to mess on production.
I get your point but I believe the roller lifters are much more produced now and likely have tighter quality control. Can't say that for sure but I have not heard of any roller lifter problems and I hear of flat lifters having troubles all the time these days.
Also, flat-tappets require careful drive-in. How many are willing to admit publicly it was their fault? How easy its blame the lifter when they round their cams...
Once again, just my opinion and thinking. Im not denying anything, rollers for sure are better engineering, but i dont believe what internet says is the whole truth about it.
I had a cam that wasnt hardend from howards..bent during brake in. I didnt catch it. I blamed the chirping sound on my alternator. Turns out the cam wiped out the bearings. I managed 500 miles. I caught it just in time before i killed the block. Howards shrugged it off as my fault or summits shipping. They fixed the cam straightened it and did the last hardening process. They did nothing for me. I asked for some stickers and got a nasty phone call. I gave the cam away and bought lunati. That lifter set from lunati which has had a lifter bleed issue on 2 lifters from day 1. Im ok with it as engine has 4k miles on it now. It just taps for about 10 secobds when fired up cold.
Just venting here.
*sigh*
*sigh*
I would spread the work about this poor workmanship.
jones1978
October 15th, 2014 08:36 PM
craftsmen22
May 19th, 2009 02:32 PM
