Gas Gauge Always on Empty (69 Cutlass S)
Old Dec 18, 2008 | 09:24 AM
69CutlassSConvt's Avatar
Hi All: This is my first post. Coming down to the end of a 10 year resto on my 69 Cutlas S Convertible. I need a bit of advice related to my non-working gas gauge. It is on "E" and stays on "E" when full or empty. Should I be looking at fuse, sender ground wire, sender wire to gauge, sender unit itself or all of the above? I would like to not drop the tank but will if that's what it takes. I do not want to do the milage v. gallons drill. Any advice on where to look first would be appreciated.
Thanks,
Dennis
Old Dec 18, 2008 | 11:08 AM
KeithA0000's Avatar
69CuttyS
Check all you wiring first, but I'll bet you'll be dropping that gas tank...
Old Dec 18, 2008 | 12:36 PM
bigoldscruiser's Avatar
2 '66 98's
What to look for --- The tank unit is actually a variable resistance ( approx. 0 to 90 ohms) to ground. If there is an open circuit, such as a broken wire, the gauge will always read "full". If the lead is shorted to ground, the gauge will always read "empty". This is presuming the dash unit is good. Failure of the tank unit usually results in a "full" reading. Happy hunting, Bruce
Old Dec 18, 2008 | 04:02 PM
ozoneblue's Avatar
Gas Gauage
Start by diss conecting the sender wire in trunk area Pink I think & watch gauge then move forward , If I rember right the wiring goes under the door sill plates Good Luck vintageozarks.con
Olds442toro
May 31, 2014 07:25 PM
at3reg98
Apr 17, 2012 10:36 AM
Deputy442
Apr 14, 2009 07:42 PM
Jakespeed63
Jan 14, 2008 07:55 PM
