Glasstek OAI Hood Question
Old December 21st, 2017, 06:40 PM
sleeton's Avatar
So I was able to pick up a glasstek OAI all fiberglass hood for my 71 cutlass convertible . I have purchased as well the lightweight springs and the chrome twist and lock down ***** set. My question is once I install the hood do I still use the existing hood latch system with the t-handle release or do I remove all of that and just use the lock down twist *****
sleeton is offline
Old December 21st, 2017, 07:59 PM
cherokeepeople's Avatar
this has been about 20yrs since i sold my w-31 but if i remember correctly it still had the t handle and secondary catch.the twist ***** were basically insurance.
cherokeepeople is offline
Old December 22nd, 2017, 09:02 AM
classicmuscle442's Avatar
Use both the original hood latch and the twist locks. Not sure but maybe they were worried about the hood flexing at speed or because it looked cool.
classicmuscle442 is offline
Old December 22nd, 2017, 10:03 AM
sleeton's Avatar
Thanks for the help, hope to install the hood over the holidays
sleeton is offline
Old December 23rd, 2017, 04:30 PM
Gary M's Avatar
The pins in those chrome hood locks don't look strong enough to me. If they fail you better have a change of shorts with you. GM used the stock hood releases with the OAI hoods from the factory.
Gary M is offline
Old December 23rd, 2017, 08:03 PM
Make sure the pins in the twist lock are secure so they stay centered. Some have had the pin move off center and then can't get hood open. Checked mine and they were tight, so not sure if it was the repops that had the problem.
Old January 14th, 2018, 04:35 PM
sleeton's Avatar
Well after getting through the holidays i was able to install the hood. But, the fiberglass hood has no holes or bolt holes to allow the factory hood latch to be installed thus forcing me to only use the twist *****.
Any thoughts??
sleeton is offline
Old January 14th, 2018, 04:53 PM
Gary M's Avatar
Make it a point to mention to any mechanics that work on it not to slam the hood. When I first got my black cutlass it had the fiberglass hood and I heard a mechanic repeatedly slamming my hood. I hollered out the door "stop". He thought it was like stock. Fortunately no damage but DAMN!
Gary M is offline
Old January 14th, 2018, 06:55 PM
Well, I hit a deer with my 71 back in 96 or so. I couldn't find a good hood and asked the body shop if I could get a aftermarket OAI hood and the insurance company did paid for it. It was a glasstek. It was sent to the body shop and they didn't know how to latch it and neither did I. So they put it on and finished and painted it. It's been over 20 yrs with using just the hood pin latches. I would NOT recommend doing what I did but it has been fine for years. Of course it would only take one time of forgetting to latch the pins for disaster to happen. EVERY time I close the hood I latch it. EVERY TIME, even if I think it won't be moved I still latch them. Also when I drive the car I look down the hood and can see the left pin and make sure it's latched. I don't recommend it but that's what I still have.... Now that the car is older and better I plan to go back to a regular steel hood, which I have since bought.
Greg Rogers is offline
Old January 15th, 2018, 03:50 AM
CutOvers Olds Parts Guys
Bee Saint Louis's Avatar
I bought an all glass hood also. I removed my T handle, latch and hood pop up spring. I'm waiting on my hood pins to come in the mail now.
Bee Saint Louis is offline
Old January 15th, 2018, 06:16 AM
72 Olds CS
RetroRanger's Avatar
There was a thread on here where someone had reinforced the latch area on a fiber hood so they could use the factory latch besides the twist locks. The factory hoods had a metal frame w a fiber top, the glass Tekhood is all fiber
RetroRanger is offline
Old January 15th, 2018, 12:04 PM
72 Olds CS
https://classicoldsmobile.com/forums...ety-latch.html
Brandon modified his hood in this thread
Old January 15th, 2018, 07:05 PM
stevengerard's Avatar
The Cutlass I just grabbed has an older glasstek hood with only the pins, been on there for probably 12 - 15 years and no problems yet. Though the previous owner lost one of the pins. I noticed it the first time I took it down the expressway , had to slow down real quick!
As for the little pins moving on the twist lock my W30s have that problem and they are original twist locks. Every time I open the hood I double check to make sure they are in the correct place. I bent them just a little so they don't slide as easy. Some folks dab some adhesive on there others use wire-cutters to crimp them that creates a lip on each side that prevents it from shifting.
stevengerard is offline
Charles Hosley
Body work
December 4th, 2016 06:08 PM
Sampson
December 13th, 2014 06:03 PM
ziff396
Body work
16
November 27th, 2011 08:41 PM
442Cliff
Body work
July 16th, 2010 08:55 AM
Quick Reply: Glasstek OAI Hood Question
