1970 455 Crankshaft Cracks
Old Dec 14, 2017 | 06:39 PM
sanded1's Avatar
Has anyone seen a 455 crankshaft develop small hairline cracks 180 degrees apart in the rear main seal area ? 25 years after a major restoration including a complete engine overhaul I pulled my 455 for a reseal and inspection. While replacing the rear main seal I noticed (2) hairline cracks about 3/8 of an inch long running length wise 180 degrees apart where the rear main seal is. My question is aside from the obvious is this thing junk ?
Old Dec 15, 2017 | 05:27 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Put up pics.
Old Dec 15, 2017 | 07:23 AM
sanded1's Avatar
1970 442 455 Crankshaft Cracks
Not sure how to do this
Old Dec 15, 2017 | 07:46 AM
Never seen anything like that before. Are they exactly 180 deg apart? If so, that's suspicious. The stock rope seal is supposed to be trimmed against the crank. If the seal was replaced with the crank in place and the engine in the car, it's possible that the installer cut or hammered too hard on the ends of the seal, causing scratches that turned into cracks.
Old Dec 15, 2017 | 11:34 AM
sanded1's Avatar
Your right upon closer inspection (polished the area) they are scratches from a previous install. Thanks, I just saved $500. for a crank
FlyingV5150
May 6, 2014 08:20 PM
71POWER
Suspension & Handling
Aug 16, 2013 07:30 PM
1968Cutlassfallbrook
Mar 29, 2012 01:22 AM
leepear
Body work
44
Dec 9, 2011 03:16 PM
capt.
Mar 18, 2010 07:33 AM
