Restore 68 Hood Vents/Inserts?
Old December 28th, 2017, 05:54 PM
olds70supreme's Avatar
My 68 Cutlass hood had three inserts that were chrome or stainless fins w/ flat black paint in between in the grooves. The paint is flaking but the chrome looks good. Any ideas on how to restore these? Would aircraft stripper to remove the paint, rinsing to clean, painting the whole thing w/ flat black, than polishing the paint off the tips of the "fins" work? Or is there a better way?
olds70supreme is offline
Old December 28th, 2017, 09:29 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Thats how I did mine. As you can see the rear "grill" is body color.
droldsmorland is online now
Old December 29th, 2017, 05:03 PM
allyolds68's Avatar
I used aircraft stripper and it took many coats and lots of patience. Then I painted it as you described above. FWIW the aircraft stripper barely touched it.
allyolds68 is online now
Old December 30th, 2017, 07:52 AM
'72 Cutlass ragtop
70sgeek's Avatar
I recently restored a pair of '72 hood louvers - they were in great condition, with barely pitted chrome and only the original gold paint finish on the fins.
I gave each 1 pass with stripper to remove any loose/flaking paint finish and then used the remaining original finish as a base to grip the new paint.
I masked off all the chrome and applied a gray primer base, then gloss black on the fins to contrast the chrome.
They went back on my red hood and look great.
70sgeek is offline
tru-blue 442
December 13th, 2014 08:38 AM
servexcell
June 5th, 2014 04:42 AM
sammy
January 20th, 2014 07:35 PM
bulldog
January 4th, 2011 11:44 AM
sed1945
October 28th, 2005 05:13 PM
Quick Reply: Restore 68 Hood Vents/Inserts?
