Worn Down Ignition Key - 1970 GM Key Code
The only set of keys I received with my car are the original GM keys. I need to get copies made, but the ignition key is "too worn down" per the two locksmiths I've gone to. I have the original paperwork which lists the GM key numbers / code. Does anyone make copies based on that? The trunk key was able to be copied without issue.
AndyBee
Jul 2, 2011 01:13 AM
