PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Cars and Coffee--Las Vegas
  2. 1970 W30 4-speed @ Mecum Kissimmee
  3. 442 Shipped to Mesa Proving Grounds
  4. Gasket set
  5. 1967 Technical Bulletins and Service Guild
  6. Dropped nut into oil send unit gallery
  7. Seatbelt question
  8. 69 trunk edge molding
  9. Suspension/Steering Part Brands
  10. trim tag
  11. U25 RPO luggage compartment lamp
  12. Marine Carburetor Center
  13. Compression on 350 Rebuild
  14. BOPC SWAP Feb 20, 2022 in Chicagoland returns
  15. ID this block casting
  16. 1962 Starfire AC elbows
  17. Distributor identification
  18. FI Tech Rant
  19. Sellers remorse.
  20. Happy Holidays from Everyone at RockAuto
  21. First Swap in 2022
  22. Rare combo
  23. Mini starter recommendation
  24. Is this a case of mis-matched motor mounts?
  25. 1972 Inspectors Guide
  26. Model cars
  27. Tire Ad
  28. Are gas prices affecting how often you drive?
  29. "THE TENDER BAR" movie is out 12/17
  30. This might be old, fist time I’ve seen it
  31. Hole in fuel pump arm
  32. Are these date codes?
  33. Help ID and verify please 1970 Oldsmobile 442
  34. Intake choke tube removal
  35. Interesting old car review
  36. Rallye 350 question
  37. My 54 in a Movie
  38. ignition lock
  39. Throttle linkage rod to tunnel ram?
  40. Trans.-Filter
  41. Anyone know where to get 70 vista cruiser rear axle bearings and seals?
  42. rocket performance
  43. hard to find oil
  44. timing question
  45. Need a little help…hopefully.
  46. Oldsmobile Experimental
  47. New to site, W30 car questions?
  48. Experiencing Mecum auctions
  49. Gauging interest
  50. Firewall Tag Info
  51. Castrol Synthetic High Mileage 10W30
  52. G-body sway bar fit A-body?
  53. Quickest production Olds 1964-1988
  54. 1973 Cutlass ?
  55. 8 track housing
  56. Took them out for a cruise today
  57. December Car Show.
  58. 1968 cutlass s headliner
  59. An Olds I need to get
  60. Torque Converter Slippage
  61. Factory ring and pinion sets
  62. Hurst Hairy Olds Press Kit
  63. I have a question about pricing of parts
  64. Getting Ready to buy tires, any thoughts?
  65. New quadrajets
  66. Oil Filter Test
  67. Anyone near Pleasanton, CA.
  68.  Air Tag
  69. Trying to find info on our 70 442 convertible cowl tag
  70. Check out this view of a '72 Cutlass.....
  71. Ladder bars on a cutlass?
  72. Edelbrock is shipping!
  73. Red Fender Liners
  74. 1979 W30 broadcast sheet
  75. Cutlass and rocket logo
  76. Mecum Kissimmee 2022 - "The Joe Spagnoli Collection"
  77. Radiator resource advice
  78. Choke Tube & Pipe Questions
  79. Help identifying an intake?
  80. 1964 olds cutlass power antenna
  81. Scanner suggestions?
  82. Aluminum Trim
  83. Cab Pouch
  84. Help Identify this Document
  85. Die Cast 1957 Oldsmobile Super 88
  86. Roadtrippin...like a Boss!
  87. Lucky breaks
  88. How many remain?
  89. Turkey Rod Run Olds Today
  90. Two kinds of manuals?
  91. Headers
  92. 1970 only Sport mirrors
  93. Goofing around while eating breakfast yesterday...
  94. How late did they make the 442 in 67?
  95. Mcacn
  96. 1972 Cutlass Door Fit
  97. MCACN OLDS PICS Second try!
  98. Mcacn olds pics
  99. 68 Cutlass S Carburetor Replacement
  100. '64 Starfire cooling
  101. Cam advice
  102. Easy Holiday Shopping This Year!
  103. Small press on letters
  104. Morel hydraulic roller lifters are available
  105. identify this part ?
  106. 1960 a/c clutch pulley bearing number
  107. 64 442 owners
  108. Frame Cribbing.
  109. Gray/green felt trunk mats for 70-72 Cutlass
  110. OPGI Black Friday sale
  111. Battery tray 455
  112. Question about build date
  113. Rim ID and cool tire
  114. Looking for my fathers Cutless
  115. Correct trunk mat
  116. New Quadrajet Manual
  117. N. Carolina to SoCal?
  118. 68 442 Cowl/aftermarket hood
  119. 1500A-4000A jump packs vs. SBO/BBO?
  120. Factory wing trunk pics
  121. Tire date coding expert?
  122. Forged cranks in 455’s
  123. Puff of smoke and oil
  124. Seat belt retractors, old aftermarket ones
  125. Moultrie Swap meet
  126. Veterans Day Car Show Bastrop, TX
  127. Simple chrome repair
  128. Vacuum hose help 71 2br rochester
  129. Tracing Ownership!!!
  130. 72 350 intake question
  131. ‘66 442 Convertible - Advice Needed
  132. Avg cost of a 1970 Cutlass s in 1970
  133. Honda shows off the latest version of its 'Autonomous Work Vehicle'
  134. 4GC carbs
  135. 1969 Hurst Olds w/AC
  136. location of Cutlass build sheet
  137. Is this a trans part?
  138. Trans DUST COVER 455
  139. Question about 4 speed motor
  140. Is there anything special about an Olds 425 engine?
  141. Oldsmobiles on TV
  142. What is it???
  143. Indoor Car Covers
  144. 68 Cutlass Hood Louvers
  145. Best hood/ view ever?
  146. 1960 Super 88 engine mounts
  147. Convertible Top Frame
  148. Trunk latch striker support
  149. All electric by 2030
  150. Identify engine bay bracket 1965 442
  151. 1971 Cutlass Shifter Decals
  152. 72 GM TH350 Trans Governor
  153. 68 400 paint
  154. Muscle Car and Corvette Nationals 2021, Nov 20-21st
  155. 72 Supreme surprise
  156. Gold Medal Edition Cutlass
  157. In search of..
  158. belts rubbing...need ideas
  159. Found some ads for the 76 Cutlass S, figured I'd share
  160. 2022 oca nationals
  161. 1964 Oldsmobile 330 intake heater core fitting (Lots of pictures)
  162. Battery tenders / minders
  163. Question about spiral shocks
  164. Beautiful fall day, I'm off work, and honey dos are done...so...
  165. Simpler times
  166. Enclosed car carrier needed
  167. Does anybody know?🤔
  168. 70 stripes
  169. GM Colors
  170. Headlights
  171. How do I replace to passenger rear spark plug?
  172. Alternator rebuild
  173. 68 oldsmobile delmont help
  174. 260 V8 question
  175. Was a reverberator an option in 1965?
  176. Oil change time, preferred BBO filter? Wix 51049 or 51258
  177. 1967 442 4 speed
  178. 1960 Super 88 Trim identification
  179. Paint Stripper New Formula Sucks!
  180. Hot rod hootenanny 2021
  181. Matching Numbers or swap (opinions)
  182. 1969 Hurst Olds gauges rally pack in padded dash
  183. 65 cutlass trim
  184. Anyone Successful With Title Companies
  185. 67 400 dipstick Info Help
  186. Shipping a Quarter Panel - Advice / Parts Relay?
  187. 1969 Hurst Olds dash question
  188. 1969 Hurst Olds
  189. Any glaring read flags???
  190. Need help tracking down ignition problem
  191. Leaks, leaks, and leaks. Who’s got em, and what’s leaking
  192. The Power of Vinegar vs. Rust
  193. Oldsmobile in the news
  194. Typical speeds?
  195. Anyone need a good laugh?
  196. A humbling day...
  197. GM compatable 1970 front 98 bench seat frames.
  198. 1969 442 on BAT
  199. Alamogordo, NM project cars on Craigslist
  200. Rattles, rattles everywhere
  201. Red 70 pj.s forsale
  202. Determining fair price for W31 350 Rocket
  203. '64 4-4-2 Canton, Ohio
  204. Fuel pumps
  205. 70-72 AC compressor rebuider ??
  206. Tunnel Ram on the street?
  207. Looking for feedback on 1967 Cutlass Supreme
  208. Ever have dealings with...
  209. Electrolysis rust removal
  210. '71 Rear Bumper HELP
  211. MSRP source
  212. Correct engine color
  213. Touching story about a man and his mom's Oldsmobile
  214. 70 W30 AC car - any R-12 out there ? :-} )
  215. Convertible hydraulic cylinders
  216. I need some education..
  217. valves
  218. Wheel Spacers, Or Not.
  219. Master cylinder / hold off rebuilders ?
  220. Kool Poster
  221. Flare type
  222. V.I.N. in another place on body
  223. How do I fabricate this?
  224. Pics from the BOPC show in FL
  225. Jay Black passed away
  226. Anyone care to decode this body tag?
  227. THH 350 Trans cooler lines
  228. Get the “lead” in.
  229. Amelia Cruizers Car Show
  230. Relay on fender 1970 442
  231. She's on the ground!
  232. Mild rebuild/performance 403 olds
  233. NH Muscle car show, anyone going 10/30
  234. Will 324 intake,valvecovers & headers fit 1958 371
  235. Anyone in FLA attending BOP show?
  236. 1972 Cutlass will not start
  237. Is this info on super stock wheels accurate?
  238. Alternator - 1100890
  239. What do the experts think about this engine.
  240. 71 Cutlass battery
  241. B&C Bigblock heads value
  242. Oldssled
  243. Raising a car from the dead
  244. Feedback on this car as well, thanks
  245. I am interested in this car, what are your thoughts?
  246. Rebates!
  247. Fuel pump on 69 Toronado
  248. Off topic, Ram 1500 random battery discharge
  249. How about some "close ups"
  250. Pull manifold?
