What do the experts think about this engine.
Oil fill cap should be shiny, not painted. Altenator is not open face. Why go to all the detail and not connect the washer fluid hose to the cap. No stickers on the air filter lower housing or Oil fill tube
A few other small nit-pick items: upper radiator hose and bypass hose have chevy style clamps (should look like the clamp visible on the lower radiator hose). As far as I know, the wire going from the battery to the horn relay should be on its own, not wrapped in the alt/ engine harness. It also looks like it may have a drum brake master cylinder, but also has the disc brake valve below it. Over all though it does look very presentable. Agree that is does look like toro engine blue.
And obviously they are reproduction inner fender wells.
Hood hinges and springs are incorrectly painted.
Are the double threaded head studs right for this car? Shouldn't this just be under the heat shroud?
Yes - correct location for AC bracket. And on drivers side a similar bolt is in place for a drivers side mounted alternator bracket which this car does not have.
So my question is were these bolts installed on all engines regardless if the accessory brackets would be there or not?
1968CutlassSupreme
October 23rd, 2014 12:40 PM
