Question about 4 speed motor
Old Nov 14, 2021 | 05:33 AM
71benchseat's Avatar
I have a random and probably dumb question. I see a lot of guys saying you have to have a 4 speed motor if your wanting to do a Manual set up
And one from a automatic won’t work. So My question is can a 4 speed motor be used for a automatic setup
Old Nov 14, 2021 | 05:38 AM
fleming442's Avatar
Yes, a manual trans crank can be used for an automatic. The problem is going from auto to stck because the crank is not drilled for the pilot input. I tried several times, unsuccessfully, without having the crank drilled properly.
Old Nov 14, 2021 | 05:39 AM
2blu442's Avatar
Yes you can do that without any problems. The issue is most Oldsmobile crankshafts are not drilled for the pilot bearing. That's the difference that becomes a problem swapping from an automatic to manual transmission.
Old Nov 14, 2021 | 05:41 AM
gs72's Avatar
72Cutlass S
Yes. The reason some engines won’t work for a manual set up is because the rear of the crankshaft is not drilled for a pilot bearing. The pilot bearing supports the end of the input shaft. Since an auto doesn’t need a pilot bearing either engine will work.
Old Nov 14, 2021 | 05:42 AM
gs72's Avatar
72Cutlass S
I guess we were all typing at once. 😂
sx455raidercelticfan
Jun 2, 2021 08:01 AM
s i 442
Jul 14, 2013 04:41 PM
Propaneking
Jul 27, 2012 06:09 PM
Wilson05
19
Aug 2, 2009 05:47 PM
oldcars
May 10, 2008 12:48 PM
