PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Deal of the week at Carlisle
  2. 65-66 Big Car vent window reproduction test
  3. What's on your bucket list?
  4. Upcoming build on TV’s Detroit Muscle!!
  5. Starter Restoration
  6. Hold on to your hat
  7. Rare find on ebay
  8. W30 Red Plastic Inner Fender Liners
  9. 1969 Oldsmobile 442 Quadrajet Choke
  10. Shifter bracket
  11. 69 442 Console Removal
  12. factory rubber or urethane
  13. 1970 Cutlass Values?
  14. True OAI hood?
  15. 1972 Cutlass 3 pin radio power connector
  16. 72 Cutlass Body and Frame What's it Worth? (Not mine)
  17. Spring Jefferson
  18. The Batman - Batmobile 2022
  19. All 66 98 LS Had Boxed Frames?
  20. Clips for shock absorbers?
  21. cam bearings
  22. Rag joint
  23. Oddball Olds Speedparts
  24. 71 442 for sale in classifides
  25. 64 production
  26. Older Restomod - advice needed
  27. Spam from Jegs!
  28. how to use hard top frame under a convertible
  29. Sedan man
  30. 4 speed shifter ball.
  31. Distributors
  32. Seal Kits - The Best
  33. wing windows interfering with mirrors
  34. Summer plans for the 67 Gasser
  35. 1968 cutlass tire size 15x8 wheels
  36. wow to view rallye 350 photo of cars awaiting stripes outside lansing
  37. '62 Starfire Foam Headliner Color
  38. air compressors
  39. Moroney Label
  40. VIN numbers on catalog cars
  41. were you looking for a Oldsmobile ??
  42. Teflon tape or no?
  43. 70 442 power windows wiring diagram
  44. 62 Starfire AC vent elbows
  45. I love all cars
  46. 68 cutlass supreme
  47. Oil question
  48. Anyone Near Colorado Springs to Look at a Car?
  49. Will E15 Hurt My Engine ?
  50. Selling at the OCA Nationals
  51. Insurance
  52. Repop parts?
  53. Spark Plugs
  54. Just thought I'd share this...
  55. Valve Cover Gaskets
  56. First generation olds engine in buick 1956
  57. First car show of the season (for me anyway)
  58. Says documentation?
  59. Tri-Carb sales
  60. CSM cheap on Ebay
  61. Cutlass S and Cutlas Supreme
  62. 69 Deluxe seat belt retractor
  63. Correct Radiator Cap for a 72 U code non air
  64. What is this called and where can I get it?
  65. 1972 U, V and X codes?
  66. Transmission Dip stick and Tube TH400
  67. Sad to Lose BR
  68. Plugs w/petronix
  69. RockAuto.com Discount Code - Expires July 5, 2022
  70. Off Color Randy C
  71. Ep. 342 of What is it?
  72. For the LS Fanboys
  73. Station Wagon Value Increases
  74. W30 aluminum intake
  75. Monster Jam
  76. '71 Cutlass vinyl top question
  77. 65 442 (?) vert for sale in Tucson
  78. Piston Power Show Cleland 2022
  79. 1st Big St. Louis Cruise-in 2022
  80. DYI Oil Change Question
  81. FOUND: W43 crate motors
  82. wire set choice
  83. Looking for a 68 442 convertible boxed frame.
  84. Looking for a 68 442 convertible boxed frame.
  85. The 66-67 W30 Syndicate @ MCACN 2021
  86. Alternator Bracket/ Brace
  87. Was this a 1972 item?
  88. What Became of Schurkey?
  89. Fan correct way?
  90. Water pump
  91. J&S Machine Ga stage 1 heads
  92. 60s air conditioning
  93. Let's Rumble dudes.....
  94. After 15 Years
  95. delays
  96. 1975 Omega
  97. Did You Know......?
  98. Viet Nam Veterans Day
  99. decoding cowl tag
  100. D heads value
  101. 1965 jetstar1 how many are on the road today?
  102. rockauto discount where is it?
  103. Possible good news for anyone restoring an interior?
  104. 1965 442 radiator identification help
  105. diy roll over jig
  106. Fan and clutch clean up / Restore
  107. 1970 vs 71/72 Exhaust heat riser pipe
  108. How cool is this picture
  109. Replacing/Upgrading Radiator
  110. 69 442 exhaust system
  111. Oldsmobiles at Daytona spring car show
  112. Insurance Inflation
  113. 1972 Cutlass ralley gauge conversion
  114. Tips on a 68 442
  115. Valve cover gaskets
  116. First generation harmonic balancer rubber
  117. 73 cutlass salon stats
  118. moment of truth
  119. HP ratings for 1976 and 1977
  120. back in an Olds again..
  121. 65 Billet Aluminum scoops & tail light bars
  122. AC R12 or 134A?
  123. removing windshield wiper arms from the linkage.
  124. Starter
  125. Looking for Old post
  126. Header gasket sealant.
  127. The Luckiest Driver in the World
  128. 86 REGAL idles BUT no power
  129. Turkey trays
  130. 67 Cutlass RH Mirror?
  131. 65 jetstar1 timing
  132. Options for stripped motor mount to block hole
  133. 8-track Tapes Repaired
  134. Back to back cruise ins..
  135. Cruise control
  136. hinge pins
  137. Swap meet TSRA Tucson
  138. Old REO Ad
  139. First cruise in of the year..
  140. Drive it like you have an egg between your foot and the gas pedal
  141. Emblem ID help
  142. Radiator Connection - 69 Cutlass
  143. Buzzing noise
  144. Is this an olds oil pan?
  145. Cam break in at the factory
  146. 1970 Cutlass door and quarter window diagram
  147. Rebates!
  148. Trunk Light
  149. Vintage air and inflation
  150. My new assistant
  151. check out this gem/ SX
  152. 1966 Dealership books
  153. Quadrajets
  154. Engine Revving High
  155. I've lost interest....
  156. 87 Cutlass Supreme Brougham Smog Question?
  157. AutoRama Show / Dallas / 2022
  158. Mobileparts
  159. Hood Lock with A/C
  160. Painted rally wheel black
  161. Reproduction wiring
  162. Oldsmobile dealership clock??
  163. RE-Stamp, or legit
  164. Thiel motors De Witt, IA
  165. Radiator tank Info
  166. Dealer emblem license plate frame
  167. 34th Annual Olds Show phoenix
  168. L33, ever with 3spd manual? (1970).
  169. 442 Post. Bat. Cable
  170. 76 quadrajet
  171. Trunk mat?
  172. Engine Mystery Gasket - Olds 350
  173. how to verify a numbers matching car
  174. Crushed Oldsby whale blubber!!
  175. Quadrajet book by Everyday Performance LLC now on AMAZON
  176. Cowl Tag Interior color
  177. 69 alternator usage
  178. Oil Pan Gasket - 69 455 Cutlass
  179. 10 days in at the purchase of my 70 442 hey y'all
  180. dream car
  181. 455 2 barrel carb and intake, is it desirable or junk
  182. How to get in the trunk???
  183. "ZR" radiator tag availability
  184. Engine id #
  185. Life can be like a fairy tale !!!
  186. Follow the Red brick road
  187. 455 identification help
  188. Stolen 70 Toronado GT in Allentown, PA
  189. G-Body olds kaput?
  190. Does anyone bother with reading instructions???
  191. Timming Issue
  192. car cover
  193. Stolen 70 Olds - not mine
  194. In the wild
  195. Stolen GSX / Detroit area
  196. Olds mobile distributor questions
  197. P\S fluid leak?🤔
  198. 64 olds 98 2 door coupe
  199. Cutlass Roof Rack?
  200. 72 w30
  201. Steering column rebuild.
  202. Newbie looking to rebuild 455 rocket
  203. W25 hood pins, replacements
  204. Remanufacturing Cars 25 Years Or Older
  205. Air cleaner decal
  206. 70 sending unit vs 71-72
  207. Old, unopened motor oil
  208. F85 vs Dynammic
  209. 455 rebuild cost?
  210. Engine block color
  211. 1955 windshield installation
  212. 68-69 vs 70-72 fuel tank
  213. Sometimes you gotta do what you gotta do...
  214. 59-67 V8 oil drain plug tool
  215. Well crap!!!
  216. Beer can with 442
  217. 71 supreme
  218. Broadcast Card for Rallye 350
  219. Thinking of buying a Toronado, whatcha think?
  220. VR1 20w50
  221. New used 70 442 engine
  222. 40s olds for viewing
  223. Gardener exhaust pics
  224. 1964 330 passenger side timing tab. Where do I buy one new
  225. Olds at AACA winternationals Melbourne FL
  226. Tic/Toc Tach for 72 442 Install
  227. bumper replating
  228. Cleaning Speedometer Cable
  229. Oldsmobile W-43 Engine
  230. 2 bbl carb
  231. Turn signal switch
  232. Throttle cable bracket
  233. Piston ring filer
  234. Need help with Demon carb!
  235. Edelbrock 600 CFM--undersized?
  236. heads
  237. Dreams of getting it out squashed again by weather
  238. Oldsmobile at Kindig Design ?
  239. My Jetfire on Jay leno's Garage!!
  240. Preformed brake lines
  241. Rayloc remanufactured starter
  242. 63 Jetfire I drug out of a barn in Iowa
  243. More Alternators, Axles, Batteries…
  244. 65 trunk pans
  245. 70 Purchase, what are the odds
  246. Rotors
  247. Did I ruin my ball joint
  248. Is this extra MSD mess required to run?
  249. Unknown connector taillight harness 01 S-10
  250. New member 69 Cutlass
