455 2 barrel carb and intake, is it desirable or junk
I would say yes it is worth asking. The SX came with a 455 two barrel. Might be plenty of others also that would want it. Post a picture with any numbers etc on it. Someone here will tell you exactly what it is.
Maybe I am way off but I think someone would want it. Sounds like you are a cool dude that isn't looking for crazy money.
You won't sell it if you don't offer it for sale!
List it here and anywhere else you might think of, like FB marketplace if you use it. Worst case is nobody's interested, then you can drop it at the junkyard and not have to wonder whether it was actually scrap!
It came out of a 68 or 9 definitely a Delta 88 and I saved the Posi Pumpkin, I thought it would fit my cutlass but Monza said not going to fit. Interesting car had buckets and a center console. I took the engine and the rest was a big mistake.
Thanks I will pull it out of the scrap truck run and get some pics of numbers. Should I continue to post it here or choose another place?
Sorry I just noticed other replies while I was typing.
I think it is neat, cuz it's the way they used to do things... big ole 455 torque monster with a simple 2 bbl carb. Now a days it's little bitty 2.7 V6's with turbos in a big F150 etc. But is it worth anything? Prolly not, except to the guy who has one already and wants a spare.
Mike
Not even close. The large bore 2GC used on the BBO was rated at 500 CFM, but there's a huge asterisk on that. 4BBL carbs are rated at a pressure drop of 1.5" Hg. 2BBL carbs are rated at a pressure drop of 3" Hg. You can't directly compare the two, but you can be 110% sure that the 2BBL is more restrictive.
The tri-carb doesn't use the large bore BBO 2GC. The small bore 2GC is a lot closer to that 350CFM number. Even then, the issue is the pressure drop used for testing. Higher pressure drop causes a higher flow measurement. The reason for using the higher pressure drop when testing the 2BBL is because it is more restrictive than a 4BBL at W.O.T., so there is more of a pressure drop. I've seen some data that claims that these 500 CFM large bore 2GCs flow about 390 CFM at a 1.5" Hg pressure drop. When you have multiple 2BBLs, the pressure drop is less because there's more venturi area, so the 1.5" Hg differential would be more appropriate. Test three large bore or even small bore 2GCs at 1.5" Hg simultaneously and you'll get a LOT less than 1500 CFM. You'll probably get a lot less than 1050 CFM for that matter.
You are correct about the center carb, my mistake. The fact remains that the large bore 2GC is rated at about 500 CFM when tested at 3" Hg and has been shown to flow about 390 CFM when tested at 1.5" Hg. I think we're in violent agreement. In any case, the claim of flowing the same as a 650 Holley 4BBL made above is pure fantasy, which was my whole point.
I can take a better pick for you. I looked at the black plastic at the base and it looks like 2 that hold it on. I am not sure on price because of shipping. What is it worth to you?
I can use it for $50 shipped. You can ship it via USPS Priority Mail medium flat rate box for about $15. That will be about $35 for the carb but that's about all I can pay because I'm just using it for parts.Just let me know and I'll get you paid. Thanks,Mike
No,in the third picture the black rubber diaphragm is in a bracket that should be screwed to the air horn with two screws. I think it is,so I hope you saw my offer,let me know. Thanks
#33
Post 1 ---- Is there any interest in a 455 2 barrel carb and intake?
Post 2 ---- What I mean is should I post it in Parts or is it not worth it?
It took on a life of its own but I believe I have it sold soon. I feel better about not junking it and as for the money will I think $50 shipped is fair.
I just need to make sure I can ship for about $15
thanks
#34
Posi Came out of a 1969 delta 88
What I found out
16B41 GM LC 267 is stamped on the ring gear teeth
16 and 41 see it with the B in between.
That is your gear ratio 2.56 41 divided by 16 = 2.56 ratio
Sorry, I thought I replied to this but if I didn't I am now
What I found out
