410670 Intake 4-barrel??
Old Jul 22, 2015 | 02:42 PM
79Cut2Tone's Avatar
Can a 410670 intake accommodate a 4 barrel carb?
Motor is a 350 Rocket from a 72 Cutlass, I believe.
Engine specs are 395558 block, 409147 #7 heads, 2009674 build code on oil filler, and 410670 on intake manifold. Last time I pulled the carb, I recall seeing 2 large circular holes and 2 smaller holes.
I asked this on a old dead thread yesterday but haven't seen any views so I thought I'd start a new one.
Thanks,
Will
Old Jul 22, 2015 | 02:59 PM
You mean like this? --
Those are 4bbl intake manifolds.
Also, if you saw this when you pulled the carb, then you may wish to ask yourself: Was that a 4bbl carb?
Old Jul 22, 2015 | 03:57 PM
Four holes on the intake is a pretty good indication that it is designed for a four barrel carb. The large/small arrangement means it accommodates a spreadbore carb, like a Qjet. A square bore carb like a Holley won't bolt up.
It's rarely a good idea to unearth an old thread.
Old Jul 22, 2015 | 10:27 PM
79Cut2Tone's Avatar
Scratch that...Looking at some photos I took when I put it in my 79, it only has 2 holes.
Damn, still need an intake and carb.
Thanks again,
Will
Old Jul 23, 2015 | 04:32 AM
BlueCalais79's Avatar
If you have an Olds 260 motor in that car (5th digit F), don't even think about putting a 4 barrel on top of it, it's too much for those tiny pistons. You will be throwing money down a rat hole. This simply wasn't done back in the day. The only way you are going to get a 4 barrel is if you go with a Chevy 305 or the Olds 350 (in the Hurst only).
However, I just looked at your car in the album, I see you have a 72 350 in it. Perhaps today might be your lucky day. I am selling my 72 Cutlass S and I will no longer need the correct year 72 4 barrel intake manifold I bought for it over the winter. If you are interested in buying it send me a P.M., it's just a dust collector for me now.
Beau Dirt
Dec 27, 2021 03:02 PM
RetroRanger
Nov 21, 2016 10:11 AM
63 F85 Cutlass
Feb 8, 2015 03:20 PM
thapachuco
Jul 27, 2013 02:51 PM
66ninetyeightls
Mar 28, 2010 07:40 AM
