2 Barrel to 4 Barrel Adapter
Does any company make a carb adapter that i can use to replace my worn 2 barrel for a new 4 barrel edelbrock?
are there any advantages to this swap besides possible hp power?
this is for a stock 371 intake manifold on a '60 dynamic
thanks!
thanks!
I've never seen a 2-bbl to 4bbl adapter that looks like it will do any good. It would have to be tall enough to allow for the mixture from primary/secondary to enter the manifold through the old 2-barrel holes.
You should be able to find a used 4bbl manifold for the 371, or even a multi-carb manifold (weren't there 2x3 and 4x2 manifolds?).
Steve
Steve
Not sure about your fuel pump and distributor compatibility but it might be worth looking into. Probably better performance than a 4bbl carb after application.
Last edited by The Roadmaster; Jul 27, 2013 at 12:58 PM. Reason: fat fingered the keyboard ... spelling errors
Beau Dirt
Dec 27, 2021 03:02 PM
