2 Barrel to 4 Barrel Adapter
Old Apr 26, 2013 | 01:03 PM
thapachuco's Avatar
Does any company make a carb adapter that i can use to replace my worn 2 barrel for a new 4 barrel edelbrock?
are there any advantages to this swap besides possible hp power?
this is for a stock 371 intake manifold on a '60 dynamic
thanks!
Old Apr 26, 2013 | 01:13 PM
halfmoontrail's Avatar
I've never seen a 2-bbl to 4bbl adapter that looks like it will do any good. It would have to be tall enough to allow for the mixture from primary/secondary to enter the manifold through the old 2-barrel holes.
You should be able to find a used 4bbl manifold for the 371, or even a multi-carb manifold (weren't there 2x3 and 4x2 manifolds?).
Steve
Old Apr 26, 2013 | 02:12 PM
thapachuco's Avatar
Yes there were 3x2's but the ones ive seen are close to $1000
oh well, it was worth a shot.
Old Apr 26, 2013 | 02:49 PM
brown7373's Avatar
JC Whitney used to sell the 2 to 4 adapters...right next to the magic beans and sqaure peg to round hole adapters. A 4 bbl manifold for the 4bbl or fixing the 2 bbl is a much better option.
Old Apr 26, 2013 | 03:15 PM
jag1886's Avatar
They do make them and they don't work too well. Like trying to put 2 pounds of poop in a 1 pound bag.
Old Apr 26, 2013 | 04:50 PM
thapachuco's Avatar
ha thanks guys. I've seen it successfully done on old straight 6 pickups, but dang.. guess i'll save up for a 3x2
Old Jul 27, 2013 | 12:55 PM
The Roadmaster's Avatar
thanks!
Even better, O'Reilly's has a throttle body setup for non-FI cars. I'm sure there are better ones from Mail Order catalogs available. I mentioned O'Reilly's because I saw their (whose ever) setup and thought it was a great idea if it worked.
Not sure about your fuel pump and distributor compatibility but it might be worth looking into. Probably better performance than a 4bbl carb after application.
Last edited by The Roadmaster; Jul 27, 2013 at 12:58 PM. Reason: fat fingered the keyboard ... spelling errors
Old Jul 27, 2013 | 02:51 PM
70cutty's Avatar
Beer Connoisseur
I have a 2 barrel carb that's in good condition. Let me know If you want it.
Beau Dirt
Dec 27, 2021 03:02 PM
jjokrm
Nov 19, 2016 03:22 PM
63 F85 Cutlass
Feb 8, 2015 03:20 PM
69oldsdelta88armyvet
Apr 27, 2014 01:02 PM
66ninetyeightls
Mar 28, 2010 07:40 AM
