1975 Omega
Old Mar 30, 2022 | 03:33 AM
deadeyejedi's Avatar
1975 Omega
Does anyone know what transmission would have came in a1975 omega with a straight 6 in it ?And aren't they unibody cars ? I may have found a body to drop a 350 in as long as the price is right and its not too much work to swap it over . Im gonna start researching more on the omegas i dont have much experience with them.
Old Mar 30, 2022 | 03:48 AM
66SportCoupe's Avatar
Most likely would be a TH350 automatic or a Saginaw 3 or 4 spd. manual.
Old Mar 30, 2022 | 03:53 AM
if its a chevy inline 6 then my guess would be the chevy bolt pattern th350? if i get this car i may have to look for a bop th350
Old Mar 30, 2022 | 05:09 AM
Can’t drag any info out of the seller he’s full of one word answers .
Old Mar 30, 2022 | 06:37 AM
^^^This. The base trans was a three speed Saginaw. The TH350 was optional. The 1975 Omega was available with the Chevy inline six, the Olds 260, or the Chevy 350. Yes it's unibody with a front subframe, very similar to the one on the second gen F-body cars.
Old Mar 30, 2022 | 06:50 AM
69CSHC's Avatar
If it's already a th350 maybe go with an adapter ?
Old Mar 30, 2022 | 06:51 AM
The two things I do know is it has the Chevy inline 6 and an automatic transmission . Not sure what crossmember they used in that application . And of course the frame pads will have to be changed for the olds 350 .Do they make aftermarket pads for this swap yet or do I have to source originals ? I read Joes post about using two different frame pads on theses .
Old Mar 30, 2022 | 06:52 AM
thanks if it’s a decent working th350 then this would be a good option
Old Mar 30, 2022 | 07:48 AM
Bigmikey65's Avatar
Omegas are fun cars. I think your swap should be relatively straightforward. Rust on these cars is a major issue - especially in the sub-frame area. You might want to get as many detailed photos from underneath the car as possible.
Old Mar 30, 2022 | 08:28 AM
Bfg's Avatar
Bfg
I’d leave the original straight six in it and have something that no one else has. 350’s and 455’s are getting boring.
Old Mar 30, 2022 | 10:46 AM
No one makes repros. You'll need to source frame pads from a 1975-79 Omega with Olds 260. If you can find those, use 2328 motor mounts. Failing that, you can probably use the F-body mounts for the 403 Trans Am. These are metal brackets that bolt to the block and mate to the Chevy clamshell-style mounts that bolt to the frame.
EDIT: It turns out that the 1975-79 X-body cars use the same frame pads as do the 1977-90 B/C-body cars and the 1978-88 A/G-body cars. That makes it easy. Be aware that these are RH/LH.
Old Mar 31, 2022 | 08:04 AM
newmexguy's Avatar
There was a light duty version of the TH 350, it was the TH 250, and from vague recollection basically was near identical to the TH 350 externally. It’s internals we’re not as beefy. The one piece lo-po TH 200 came a bit later.
Old Mar 31, 2022 | 05:12 PM
blakes7's Avatar
I hate people like that. They can't be bothered giving anyone the time of day.
Old Mar 31, 2022 | 06:03 PM
Sugar Bear's Avatar
There is a reasonable chance that the transmission is a TH250. Look on the passenger side by the cooler lines for an external band adjustment that looks like a short threaded rod with a locknut. If it's there it's a TH250.
Good luck!!!
Old Apr 1, 2022 | 04:11 AM
Good luck!!!
thanks ill look for it .
jmos4
Dec 2, 2021 01:51 PM
QS442
Nov 9, 2013 06:11 AM
rkharper330
Oct 10, 2013 07:09 PM
1970cs
Jan 30, 2012 04:29 PM
75Omega
Jun 3, 2005 03:12 PM
