Transmission Dip stick and Tube TH400
Old Apr 6, 2022 | 07:57 AM
tkcutlass's Avatar
I was all set with http://www.fusickautomotiveproducts....?number=TDS677 but it's not in stock.
I thought I saw the TH350 dip stick/tube is the same for TH350 please verify.
Is it me or is this part elusive, I keep seeing Chevy T400 tubes.
What am I missing here?
Old Apr 6, 2022 | 12:41 PM
skyhigh's Avatar
1972 Cutlass Town Sedan
rock auto lists them to be the same
https://www.rockauto.com/en/catalog/...ck+/+tube,8486
Old Apr 6, 2022 | 12:51 PM
However the Oldsmobile parts book does not...
TH350 in an A-body is P/N 6261696
TH400 in an A-body is P/N 1384735
Who ya gonna believe?
Old Apr 6, 2022 | 01:01 PM
skyhigh's Avatar
I'm gonna stop quoting these part houses, you have shown numerous times there info is way off, I trust what you say 100%
Old Apr 6, 2022 | 01:04 PM
69 Hurst's Avatar
Olds Fanatic
Trust Joe, you'll never go wrong!
Old Apr 6, 2022 | 01:10 PM
tkcutlass's Avatar
Not much luck with that GM part number but this at least shows olds T400 and not chevy https://www.inlinetube.com/products/inl14390
Old Apr 6, 2022 | 07:11 PM
As an aside, I don't know when the "under the armpit" style of 67 went to the "aim at the underside of the hood" style of 72 at least TH dipstick tube. I meant, there are at least two different ones based on year.
Edit: table up there says that happened in 68
Old Apr 6, 2022 | 09:15 PM
Many years ago I searched the parts book for a matching TH350 dipstick and tube that used the superior boot style seal, and didn’t hit the hood. When the part came in and I verified that it would fit a typical car (at the time I was working on a 80 F body with a 455 olds swap) I kept the GM parts tag so I would have the part number next time I needed it. And the next time unneeded it, I found the part numbers had been discontinued. 😡
TCI and Coan carry the matching dipstick and tubes. And as other pointed out, most parts stores will order one for a Chevy bellhousing bolt pattern, oblivious to the fact they don’t fit BOP cases. I would think summit or JEGS carry them as well.
Old Apr 7, 2022 | 05:41 AM
Yeah, I was going to say that the 1967 A-body tube is one-year-only. I'm assuming that shape change to clear the 68-72 style HVAC box, which was different from the 64-67 box.
Big Todd
Oct 10, 2012 07:01 AM
Charles Ludwick
Jan 27, 2012 06:59 PM
tmatador
Sep 23, 2011 07:09 PM
billykissell
May 16, 2011 05:58 PM
TRW
Mar 22, 2011 05:15 PM
