Since how to remove the 61-65 V8 oil drain plug comes up every so often, here's the Bonney #A650 tool for the job to give you some idea what to look for. 1/2" drive 8 point bit.
If you don't have it a 1/2" drive ratchet or extension with sharply defined corners will do the job.
Yes, it's clean and looks unused but I've had it over 30 yr. Brake cleaner does a marvelous job cleaning it after use!
