Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Oil Pan Drain Plug
Old May 8, 2011 | 06:53 AM
tpawlik's Avatar
Oil Pan Drain Plug
What tool is required to remove the drain plug from a 62 Starfire? It looks like a large allen wrench, I tried several bolt heads trying to find something that fit, but none did.
Old May 8, 2011 | 01:08 PM
rocketraider's Avatar
Oldsdruid
A good 1/2" drive ratchet should get it out. Don't use an extension as its corners will be round enough to slip in the drain plug recess. The corners on the ratchet itself or sometimes on a good breaker bar will be sharp enough not to slip.
And yes, there was a special 8-pointed drain plug tool specifically for this application, 59-67 Olds V8. You find them sometimes on tool trailers at swap meets, or possibly ebay (and the seller usually has no idea what the tool is for).
Old May 8, 2011 | 01:11 PM
gtdrvr's Avatar
had the same problem when I went for oil change then went to a different mechanic who took half inch socket put it in the plug and removed.
Old May 8, 2011 | 01:19 PM
navvet's Avatar
Socket works perfect. I changed the plug on mine for those moments when I take it to a quick lube shop....keeps the youngsters from have a panic attack
Old May 8, 2011 | 03:14 PM
tpawlik's Avatar
Thanks guys. It did not occur to me to try a square shaped tool! Good thing I have a Topsider.
While we are in the area of the oil pan. What is that large round thing on the side of the oil pan just under the oil filter for?
Old May 8, 2011 | 08:19 PM
Oldsdruid
THAT is part of the fun of having these cars. PNDSLR shift patterns freak 'em out too. I've had more than one ask me "how do you make this car back up?"
"Put it in reverse."
"WHERE'S REVERSE?!"
And when I show them, I usually get "Ain't never seen no car like this."
jensenracing77
Dec 6, 2014 11:43 AM
Johnny HR
Apr 23, 2013 12:44 PM
Dan Wirth
Oct 18, 2009 07:27 PM
Olds64
Feb 17, 2009 01:20 PM
prawnman88
Apr 27, 2007 07:54 PM
