68-69 vs 70-72 fuel tank
Old Mar 2, 2022 | 09:03 PM
yeahbuddy's Avatar
I have a 68 tank that I wanted to use on a 72. Pulled off the 72 tank and discovered the standpipe assembly. Found out more about in my chassis manual. Question is will the 68/69 tank fit and if so, can I use the 68 tank and bypass the entire standpipe assembly? The neck is shorter so not sure if it will clear the bumper? Thank you
Old Mar 3, 2022 | 11:33 PM
yeahbuddy's Avatar
For anyone wondering in the future. The tanks are pretty much interchangeable except for the different venting locations/standpipe assembly. Went in without any issue.
pauls48
Mar 23, 2018 10:53 PM
Chumley
Feb 18, 2015 09:10 AM
68vaolds
Jan 4, 2011 07:18 AM
cegulley
Oct 1, 2010 03:37 PM
olds70supreme
Mar 30, 2010 10:08 PM
