Olds mobile distributor questions
Old Mar 6, 2022 | 02:37 PM
Andy's Avatar
Oldsmobile distributors, are small blocks and big blocks distributors interchangable? Does these hei conversions like pertronix and such eliminate the need for advance springs etc and vacuum advance?
Old Mar 6, 2022 | 02:47 PM
jensenracing77's Avatar
The module only replaces the points. The mechanical and vacuum advance will still be the same.
Old Mar 6, 2022 | 02:51 PM
VC455's Avatar
Barely Registered
Andy, Olds V-8 distributors are physically interchangeable among second-generation engines (1964 and after, ex 1964 Gen I).
HEI is a term for a specific type of distributor used by OIdsmobile. It does not use points, so Pertronix does not apply.
Pertronix are only used for points replacement within points distributors. When using these, you must continue to maintain the weight and vacuum advance mechanisms originally installed.
There are other points replacements that incorporate centrifugal and vacuum advance, accessible and adjustable by a smart-phone app. These are relatively expensive.
Gary
Old Mar 6, 2022 | 02:54 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Originally Posted by Andy
Oldsmobile distributors, are small blocks and big blocks distributors interchangeable yes dimensionally, no in calibration? Do these hei conversions like pertronix and such eliminate the need for advance springs etc and vacuum advance No you still need to tailor it to your application or have someone set it up to the application?
If you want to do it right get a DUI HEI for older school approach. This means you will need to tailor the vacuum & centrifugal events.
New school is the programmable HEIs that allow electronic settings of the vacuum and mechanical settings<<<<CATS AZZ that's the direction Id go.
Old Mar 6, 2022 | 05:04 PM
Andy's Avatar
. Ok, reason I asked is a bit long so I will keep to the point best as possible.. reason I ask the question is I happen to have a pertronix I never used and figured I would put it in a stock 400 olds distributor I have..the reason is to rule out a tuning issue I am having on my w30 455.. I have put in new points, condensor, put a Ruggles kit in the carb, new plugs and am still having a lean issue at idle and a lean surge at cruise.. Plugs are showing electrodes almost white, porcelain light brown. I ran a compression test to rule out internal issues with compression, all good.. So I figured I would put the pertronix unit in the 400 distributor, install it in the W30 and see if that cleans it up.
I have set the air fuel several times-to highest vacuum, 15 inches, timing checked several times, its at 10 degrees BTDC, total at 32 all in by 2500. Now when setting the dwell it stays solid at 28, until I rev the motor, dwell starts heading down to 25 at around 2500-3000 rpm. So before I pull the carb off again I-figured I would try a different distributor.. I have no experience changing metering rods and fine tuning a carb..so in pursuit of trying not to chase my tail anymore this was my plan…any advice?
Old Mar 6, 2022 | 05:25 PM
Charlie Jones's Avatar
Phantom Phixer
. am still having a lean issue at idle and a lean surge at cruise.. Plugs are showing electrodes almost white, porcelain light brown. I ran a compression test to rule out internal issues with compression, all good.. So I figured I would put the pertronix unit in the 400 distributor, install it in the W30 and see if that cleans it up.
It sounds to me like you may have a vacuum leak.
Check all hoses and connections to the PCV , power brakes , heater , or anything else run by vacuum.
Check the carb gaskets and intake manifold gaskets by spraying them with carb cleaner while the engine is running .
If there is a leak the engine will speed up a little.
A pertronix will make no difference in performance or power from a points system.
Old Mar 6, 2022 | 05:51 PM
Andy's Avatar
No vacuum leaks, no power brakes, check all areas several times..I happen to have a pertronix I never used, I happen to have a few distributors, as stated I want to try to swap the original out just to eliminate that from the equation.. if that does not work I will have to learn how to tune tha5 quadrajet internally.. I like trying to do things myself, thats howI learn..
Old Mar 6, 2022 | 07:54 PM
Try disconnecting the vacuum advance and see if the surge goes away.
Old Mar 6, 2022 | 08:00 PM
Sounds like a lean fuel condition. The carb is not tailored to the engine, wrong adjustments, gasket set, or a potential vacuum leak....nothing to do with ignition.
Is this an OEM QJet?
What year W30?
What carb number do you have?
What sizes are the primary rods/jets, secondary rods, cam & hanger letters??
What does the primary power piston setup look like in this carb? Are all the parts there or not?
When you assembled the air horn did you pinch the primary rod hanger? Common mistake causing a very lean condition.
Need to do basic rebuild checks like throttle plate seal, butterfly valve seal & timing, Check base, bowl, and horn warp. Are the rods straight?
Once verified all is in spec assemble then concentrate on each circuit one at a time.
To get it right you need to know some specific details of your combo. Engine....cam profile, compression. Drive train, trans, converter & rear gears.
15Hg vacuum signal is OK but right on the line of having to make some idle circuit and transition mods.
Next step, the carb then gets a basic setup or ballpark tune to the above known specs, then super tuned from there.
Once you have verified everything above is in "spec" start playing around with the big levers first...IE Primary rods and jets. Then verify the AVS door clock spring is not too loose or too tight. Then look at Secondary rods hanger and cam.
If this is not an original W30 carb, consider making the power piston modification to make it adjustable... if the provisions are there.
The only way to make this less painful if you are not into playing around is to take the car with the carb installed to a dyno Or send it out for a Pro-rebuild..
Amazon Amazon
Amazon Amazon
Old Mar 6, 2022 | 08:48 PM
tnswt's Avatar
'70 4-Speed W Machine
Andy the drop-off in dwell makes me think your problem could be with the distributor shaft, or other type distributor issues, i.e. worn bushing, worn cam, etc. Bad springs in the distributor could also be responsible for your loss of dwell angle. Do you know someone with a distributor machine that could test it for you?
You seem adamant there is no vacuum leak causing your problems. I assume you know your carburetor should not possess a power piston (’70 W30 4sp).
Old Mar 7, 2022 | 02:35 AM
Andy's Avatar
My carb should not have a power piston, however when I put the kit in it, somewhere along the line it was sent out to be rebuilt by previous owner to one of this big carb companies, not a specialty company, the power piston was added I found out when rebuilding it, it is the factory 256 carb. I havesprayed carb cleaner around the carb, base of carb all along the intake to head mating areas, no vacuum leaks show up, yes thats what it feels like. Thats why I did the compression test to eliminate that burnt valve possibility. I have the original factory distributor in it, so Since that pertronix been hanging out in my tool box, I think I will install it on th3 400 distributor and drop it in, see if thats the issue or as the Good Dr said, start with carb mods..don’t know anyone with the old sin machine
Old Mar 7, 2022 | 02:53 AM
Andy's Avatar
I did that it help a tiny bit but the problem is still there.. 😞
Old Mar 7, 2022 | 03:04 AM
Andy's Avatar
Is this an OEM QJet?. -> 256 original quadrajet
What year W30?-> 1970
What sizes are the primary rods/jets, secondary rods, cam & hanger letters??. —>I do not know this, I will pull carb in afew days and try to get this info.
What does the primary power piston setup look like in this carb? Are all the parts there or not? -> looks complete
When you assembled the air horn did you pinch the primary rod hanger? Common mistake causing a very lean condition.—> when I installed I just gently dropped the rods down into the jet , didnt force anything so feel confident on that. However from your post I will be looking at all areas.. I do have Cliffs book, along with the service manual
Need to do basic rebuild checks like throttle plate seal, butterfly valve seal & timing, Check base, bowl, and horn warp. Are the rods straight? —> they looked good when I had it apart, a company called National Carb stickers was on the carb as the 3rd owner had them rebuild it, I assume they added the power piston and bigger front jets.
15Hg vacuum signal is OK but right on the line of having to make some idle circuit and transition mods. I know this info, its a 4 speed , 3:42 geras, cam is not the w30 cam was changed years ago to a crane cam, 226/234 @ 50, 491/516 valve lift, hit-282-2-nc cam
Looks like a I have a good size learning curve to work on, I am decent with most mechanical but not internal quadrajet..will take my time and see if I can do this thing..thank you
https://www.amazon.com/Rebuild-Modify-Rochester-Quadrajet-Carburetors/dp/1932494189/ref=sr_1_3?’crid=1J29J707CAVTL&keywords=carburetor +books&qid=1646625568&sprefix=carburetor+books%2Ca ps%2C100&sr=8-3
https://www.amazon.com/Rochester-Car...s%2C100&sr=8-7
Old Mar 7, 2022 | 07:00 AM
tnswt's Avatar
My 7040256 carb had been tinkered with too when it arrived. The engine ran terrible. I broke open the carb and found a power piston, and wrong jets, just for starters. I boxed the carb and sent it to Ruggles who returned a beautifully calibrated device. While the carb was out I pulled the distributor cleaned, and lubricated it, then tested on a Sun.
From the Sun Distributor Manual: "A dwell variation in excess of 2 degrees indicates worn distributor shaft or bushings."
Hope this helps.
Old Mar 7, 2022 | 09:11 AM
Andy's Avatar
thank you, I talked to Cliff, bought a kit from him, he no longer wants to build carbs. Sounds like I definitely need to get distributor out to someone for rebuild. I am goung to try DrDans thought process as best as I can, if that doesn’t do it I will seeif Cliff can recommend another builder..doubtful, he is pretty strong minded lol
Hope this helps.
Old Mar 7, 2022 | 11:49 AM
tnswt's Avatar
I doubt you are creating enough vacuum to even pull the power piston into play; that open passageway needs plugging. There should be no primary rods in your carb either. I like being hands on too, but sometimes it pays to just write the check.
Sparky's Carburetor gets high reviews from folks here, and there are others that can do your carb right, Bob Stone comes to mind, aka Carb Dr. Lexington, PA.
If you want one stop shopping check out Everyday Performance (Ken comes highly rated from the Buick community) he is great for quadrajets, distributors, and parts per posts found online here.
Best of luck to you whether you do it yourself or get help....
Old Mar 7, 2022 | 03:30 PM
OLDSter Ralph's Avatar
Hope this helps.
Sounds like the distributor needs new bushings. I just realized that with electronic distributors could have worn bushings and harder to detect. The dwell changing in a "points distributor" could pin point a problem.
Old Mar 7, 2022 | 08:43 PM
Sounds like you're performing some good logical troubleshooting steps. Makes things much easier. If Cliff did it call him and talk. He'll help you through it if you ask nice and listen.
Keep in mind there was a reason the power piston wasn't installed in the bigger power 70 carbs. Wouldnt activate the power piston properly (lean) on the BB cars, especially the 4 speeds. Rochester/Delco modified this assembly to get it fat enough to handle the BB monster.
You are very lean per the spark plug read. This means a leak or very little fuel is being introduced in the first two/three circuits of the carbs op sequence, idle/off idle/tip in.
Is the cam choppy?
How many turns out on each air/fuel mixture screw?
3g87xm
Dec 2, 2016 04:45 PM
My2nd 69 442
Sep 5, 2016 08:38 AM
Levellord
Jan 12, 2016 09:39 PM
pappyl
Sep 8, 2015 09:30 PM
Mike77
Dec 9, 2010 07:46 PM
