Clips for shock absorbers?
Old Apr 18, 2022 | 11:27 PM
Getting ready to replace the original shocks on my sons 92 Yukon. Already did the front shocks, planning ahead for the rear.
I seem to recall seeing the clips or J nuts for shock absorbers in the Dorman or Help section. I can’t find a listing or part number. Sure, I suppose I could use nuts, but it’s so much easier have the nuts and retaining clips instead of trying to fit a wrench up about the frame.
Old Apr 19, 2022 | 04:27 AM
O-Reily's & most automotive parts supply houses carry the J-Nuts (U-Type) in stock. I have a box of various sizes, but again, you should be able to find them at most parts supply stores - maybe bring the shock with you to match up the thread size. I had to replace a broken J-Nut on a front shock tower on my '71 CS when I changed shocks.
Old Apr 19, 2022 | 05:21 AM
I don't know about the Yukon, but the clip nuts used on Oldsmobile front shocks are shorter than normal. I prefer this style as opposed to the original ones with the separate nut that breaks loose and spins.
Old Apr 19, 2022 | 09:50 PM
i have plenty of those, people call those body clips. I suppose if they will fit over the frame they will work.
Old Apr 19, 2022 | 09:52 PM
this is what I’m looking for. I’m almost positive I use to see them in the Dorman/Help section of the parts stores. I couldn’t find them in the online catalog, the counter help wasn’t helpful.
Thanks!!!
Old Apr 20, 2022 | 03:59 AM
The problem with the generic j-nuts like those is that they stick too far into the opening in the LCA that the shock needs to fit through.
Thanks!!!
Ebay - search for " gm shock fasteners"
richeyb
Oct 10, 2025 11:27 AM
Eddie Hansen
Jul 13, 2022 08:53 PM
cfair
Site Help
23
Aug 19, 2021 09:54 AM
Rocket331
Body work
Sep 18, 2012 04:00 PM
golds56
Mar 1, 2012 12:24 PM
