1955 windshield installation
Old Mar 2, 2022 | 09:35 PM
Love1955oldsmobile's Avatar
Is there a method to install a 1955 Oldsmobile windshield and gasket using just one person? I can not seem to find any shops in the Dallas area that does gasket installation s or has experience with a gasket. And none will do a home installation.
It appears to me that the gasket could "modified" and then "glued" to seal against water leaks.
I have no idea what "modified" exactly means.
Any suggestions?
Thanks. Ron
Old Mar 2, 2022 | 10:17 PM
Charlie Jones's Avatar
Phantom Phixer
It would be almost impossible to install this type of windshield by yourself.
You will need to find an assistant. A nylon cord and a couple of pry tools are the only other things needed.
A spray bottle of soapy water is also helpful.
This video will give you a good idea of the procedure;
Don't expect glass shops to be any help, most of the installers weren't even born yet when these windshields were in vogue.
Old Mar 2, 2022 | 10:34 PM
I did read the 1955 thread. It was excellent.
I guess that is why I was asking for info or perhaps updated method(s).
My thought on a modification was to place the gasket on windshield. Make a strap to hold the inner lip at more than a 90 degree angle. Put the glass and gasket in as a unit then release the strap that is holding the inner lip.
That just provides a basic overview but it provides food for thought.
Ron
Old Mar 2, 2022 | 10:47 PM
Phantom Phixer
You're overthinking this.
Just do like the video shows you and use the cord to pull the rubber over the pinchweld.
Old Mar 3, 2022 | 04:38 AM
Anderson's Avatar
Exactly this. A wife, girlfriend, neighbor, niece or nephew, stranger walking down the street…you will be done in 15 minutes. I installed a new windshield in my ‘57 Chevy last year and it was a piece of cake. Used a small piece of rope like the video shows. Set the thing in on the bottom pinch weld, then while my wife held pressure on it I pulled the rope and it just popped in.
I suggest installing the seal on the windshield and holding it on with tape, and letting it all set outside on properly supportive stands on a warm day to help the rubber soften a little and conform to the windshield.
Old Mar 3, 2022 | 07:54 AM
redoldsman's Avatar
Proud Viet Nam Veteran
If you can't get it done you might try a trim and upholstery shop.
maineolds
Jul 17, 2021 03:47 PM
Tedd Thompson
Feb 23, 2020 07:53 AM
Dave T
Mar 29, 2018 11:18 AM
lonestarjarhead
Aug 10, 2015 10:31 AM
fatback
May 24, 2015 09:12 PM
